Hello Guys !
i have a silverado custom 2021. i would like to put a 3.5 lift kit on it but it seems that the one i want (rough country) only fit with the crewcab/short box truck. is there any other companies that produce a lift kit for a crewcab/medium box
thank you all
On 1/14/2022 at 2:17 PM, ElRadou said:
Hello Guys !
thank you all
I just found this 3.5" lift kit. Supreme Suspension:
https://realtruck.com/p/supreme-suspensions-3-5-lift-kits/v/chevy/silverado-1500/2022/
So far only one review, thinking about this one for myself.
Thank you. But they dont seem to tell if it fits with a standard box :(
The supreme one look pretty solid
The front suspension is the same, regardless of what cab or box length you have.  I would assume the rear suspension is the same regardless as well, but I wont stamp my name to it since I havent verified it.  Whether or not the suspension system "fits" or not not is probably not an issue at all, its more than likely a matter of varying spring rates based in differences in weights between all of the models.
Also, 3.5 inches of lift isn't extreme, but it's getting there for an otherwise stock truck and you will want to start looking at UCA's.  Numerically, its equivalent to a TB lift with an additional 1.5 spacer (very common with TB owners) so the 3.5 inches of total lift isnt horrible per se, but you are right on the verge of needing UCA's and I would start considering differential drops if you wanted to go much more.
Hello Guys !
thank you all
Have you contacted RC about the fitment? They have very good response times when it comes to questions about their kits and fitment. It was as easy as a text thread back and forth. GL
good ideai
6 minutes ago, ElRadou said:
good ideai
you were right man !
got my answer from Kirk directly at RC that's a fit and it's working with the 20' inches wheel too
I have the 3.5” lift on my Denali and I am very happy with the height and the ride quality. The drive got a little stiffer for me because I went with a 34.5” tire but the ride quality stayed the same since it works with my adaptive air ride.
  • 1 month later...
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, they can remotely disable the device. B) Make sure it's paid off. If they still owe money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
