I don't drive my truck on the daily as I have a work truck. It sits in my driveway all week. My question is, how far and how long do I have to drive it when I do use it for a regen to happen?
I'm not exactly sure, but iirc from reading this forum in the past, it's between 100-400 miles, give or take.  Depends on the type of driving.  Regen will occur more frequently in city stop and go driving.
Edited by Transient
I reset the timer each time of regen.  It varies from 11 to 13 hours.  In the winter its more frequent due to warm up idling.  Towing seems to cause more regen.
If a partial regen occurs it will resume (not restart) at it's next opportunity.
On LM2 they seem to take about 11 or 12 miles to fully complete.
There is no notification that a regen is occurring -- unless it is unsuccessful after multiple attempts and the soot load gets well above the usual regen trigger level.
Miles between regen will depend on how it is being used., but likely between 200 and 500 mile intervals -- could be as long as 700.
Edited by redwngr
Sounds like I need to drive my truck more when I take it out. I usually just go down the street to buy breakfast, which is about a mile from my house.
There are two types of regen - passive and active. Passive occurs all the time but works best when exhaust temperatures are high. Active regen is where fuel is used outside of the normal combustion process to burn off soot in the DPF. Active regens must finish within a certain number of start/stop cycles or you'll get a warning on the dash.
Towing will work the engine enough where passive regen will do a good job and lengthen the time between active regens. I see 500 - 600 miles between active regens when towing. When not towing an active regen can happen in as short as just 150 miles. I use a Banks iDash to monitor this stuff.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
