Doesn't need a new ECM. You can reprogram it with factory tuning, or, a tuner shop can tune over it.
4 minutes ago, KARNUT said:
I use to program to the redline then back a-bit I believe 5900. Then 50 percent TM and their premium engine tune. I can’t imagine a can tune jacking up that bad as he described. Unless a drastic tire size change?
Rev limits and shift points are adjustable in the tuner. Someone jacked it way up to the moon, and probably didn't understand what was happening when it hit the rev limiter, and dumped the truck. I hate when people do that and don't include the tuner! Pretty much screwed without it.
Edited by Jsdirt
That sounds like the best way to go. Thanks
I would of left it stock like my old 2001 silverado. Never had a problem with it.
Yeah, there's no need to screw with rev limits or shift points unless you installed an aggressive camshaft and heavier valve springs, and need the thing to rev out to 7k to make use of the top-end power.
I've got the Hypertech tuner on mine - bought it in '07 when my truck was still brand new.  Got a cold air intake, and Corsa cat back system, and that's it as far as mods go. It woke the truck up pretty good. I have all the transmission parameters set to stock, since my transmission is built to the moon, so all of that has been taken care of by the builder. I can actually break stuff inside the trans if I go ramping up shift firmness, since my pump is already set to run in triple-digit pressures.
Back when the truck had the original trans (before 103k miles), I cranked up the shift firmness as high as it would go. That probably got me several thousand more miles out of it. Yours is built MUCH better than mine, so you won't have to worry about that too much. From '07-up, parts quality of these trucks really took a nosedive.
As far as shift RPM and rev limits, I left all that alone, since there was no reason to increase or decrease any of that from stock.
One time I screwed up and changed the rear end gearing in the tuner - thought I had set it back to where it should have been, but I missed a key step. Every light on the cluster lit up, shift points were screwed up, and the truck was bucking and surging like crazy! Luckily I didn't break anything. The shifts were violent.  I only drove it 4 miles that way.
I'm not into the newer way of tuning with the computer stuff. I still run a 1970 LT1 in a 64 nova that's built. Much easier for me to tune.
AMEN to that! If I had my way, I wouldn't drive anything built after 1972!
We've got a '86 Grand Marquis daily driver that's all stock and original. Still runs the original OE in-tank fuel pump - 36 years, 285k miles! Try that on anything built in the last 25 years. We take it off the road every winter, otherwise it would've rotted away to nothing 25 years ago. The road salt up here is brutal.
We run a '93 Volvo 940 for a winter beater. They used top quality metals and paint on this thing - been in New England winters since it rolled off the showroom floor in '92, and has minimal rust and no rot. Slow as slow can get, but it's as reliable as a stone ax, totally unlike my Silverado has been. I'm at 117k on the Silverado, and I'm planning an engine swap already due to low oil pressure. Started burning oil at 50k miles! Had nothing but trouble with this thing since DAY 1. Brakes, ball joints, rear end failure at 97k, trans at 103k - one thing after another.
My 2001 silverado was completely stock and had 247,000 miles with normal maintenance,  water pump and alternator. Some jack wipe pulled in front of me and totalled it. I had it from new. Great truck.
Crap! Sorry to hear that. Those are great trucks - I see many well over 300k still running.
I found my 2001 sierra at a dealership with only 160000 miles. It hasn't been too bad except for the program. I will get thru that ok.
It does NOT lock the ECU / PCM. It locks the tool so you can't upload it to more than one vehicle. It also captures your stock info in the tool, which cannot be uploaded to any vehicle but the original. With a J-box you can wipe the PCM and start over.
Look at the link I posted to the picture straight from the manual - "If a service facility reprograms your vehicle's computer with an update, your Hypertech Power Tuning will be erased."
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
