I’m purchasing a 2020 Silverado, it says it has the towing package
ive seen videos of people installing the OEM brake controller
but the dealer I’m buying from says it will not work unless it’s factory installed
the plug in the “hole” were the switch goes has wires connected to it
if it has the wires to that location
and it has the 7 pin round plug , shouldn’t it be ready for the controller to be installed??
3 different dealers and none seem to know
everyone says must use an aftermarket controller
If you search the forum, I have seen several threads about this. Knowing that everything on these trucks in controlled by a computer, however, I would imagine the difficult part would be programming the OEM brake controller to work. We have the factory integrated brake controller on ours and it gives you trailer brake gain readouts in the dash cluster when making adjustments and alerts when brakes are connected and disconnected, so it is very much "integrated." Even installing factory fog lights on these trucks requires an activation code from GM so the body control module knows what to do with them.
If it were me, I would seek out an aftermarket controller as the installation is very simple (check out etrailer.com for options). Your truck is pre-wired with a connector under the dash for you to plug it in, and you can always mount it using something like 3M Dual Lock (the stronger version of Velrco) if you don't want to drill holes in your dashboard trim.
It can't be done.  The videos end with the result of it can't be done.  It is only a factory ordered and installed option.
You have to go aftermarket, no other way.  Read below.
Quote
#PIT5828A: Adding Integrated Trailer Brake Controller RPO JL1 - (Dec 6, 2021)
Subject: Adding Integrated Trailer Brake Controller RPO JL1
Involved Region or Country
North America
Condition
Some customers may request the factory Integrated Trailer Brake Controller (RPO JL1) be installed on their Full-Size Pickup or SUV when the vehicle was not ordered with the option.
This is to advise you that, if the vehicle does not have the option (RPO JL1), it cannot be added to the vehicle.
Edited by newdude
Thanks for the updates and information
does anyone know if the OEM controller could be wired into the plug provided for the aftermarket controllers ?
I know it won’t display in the info center on the dash or work with/through  the computer
but would it work as an “aftermarket “ controller?
Edited by JON Weber
No.
I find it hard to believe that they would “rough in “ the wires behind the “plug” where the OEM controller is mounted but you can’t add the controller added and then flash it to the computer.
why would GM waste the money to put the wires there???
Cheaper to build one wire harness than it is to build 8 different variations.
Added the TOW-PRO ELITE ELECTRIC BRAKE CONTROLLER, and put the knob in the factory blank location. It is better than the factory unit IMHO. I would post photos, but she is at the dealer sitting on ice. Very easy install.
Because they are stupid.  That harness is there for the control switch, the issue is the chassis harness.  They build versions of the chassis harness with and without JL1 brake control.  So, the wiring and connector for the trailer brake control module isn't even there to start with.
