This is a tune I made for someone last year. Use the compare feature to see some of the transmission related changes. Your truck has different size tires on it than this I believe so do not do anything with the shift schedule stuff or speed related items because they will always be different.
The main stuff is the Shift pressure, shift timing, torque converter and torque mngt.
I have minor changes in the shift pressure and changes in the adaptive settings. My shift timing setup is different than yours. I also turn off the torque converter for gears 1-4 and only use lock up in 5th/6th gears. As well as turning off the TCC slip for converter life. The apply/release section, only use the "NORMAL" section, that will turn off the TC in gears 1-4 and raise the MPH settings for lockup in 5th and 6th. In the TM tab I would put the shift torque factor back to stock or put it at like .9500, you really don't need to adjust that table by half like that.
This is my opinion here but the commanded AFR under WOT is kinda lean if you are running 87 octane. I'd keep that around 12.4-12.5 instead of 12.8. If running 91+ octane it's probably alright.
I run leaner if I have higher ethanol content in the fuel but I have my tables setup to use the sensor that way. Also your timing tables are higher than stock which can be okay but I don't know how it's performing. It may be too much timing for 87 octane, on my truck I'm only around 20 degrees but move towards 25-27 with E60 fuel. Also your tuner didn't give you enough wiggle room between the high and low octane table. It's only giving you 1-2 degree difference, the low octane table should be atleast 5-6 degrees less. I'd just highlight the whole low octane table and remove another 4 degrees from it.
You will have to reset the transmission adapts after flashing those changes and before starting the truck again. Just a simple step.
2015 Silverado. test.hpt
3 hours ago, 2015 High Miler said:
small update.  New trans is doing well.  I did get an updated tune to reflect the new components and its still working well.  The temps are where I would expect with the cooler and the bypass.  Highest I've seen is 140 in heavy city traffic.
I do need to get a better tune though, both engine and trans.  I have HP Tuners but I'm not very good at it yet.
If anyone is in the DFW area that has some experience, Id be happy to meet up and get a look at my tune.
what updates did you install physically into the rebuild?
did you install a larger regulator in the pump before increasing the line pressures or max peak pressures first?
I don't touch the max pressure settings. I only increased the 1-2 and 2-3 shift upshift pressures slightly.
This is posted earlier in the thread:
Builder said it’s built to handle 700 HP.  More if it had a hardened input shaft.
Edited by 2015 High Miler
Cam, thanks for this info but TBH, I have not become very proficient yet with HPT and looking at these tunes.  I've had some trouble getting my compare files to open.  Most likely user error.  Ill try again with this one.
I def would like to be able to switch fuels.  I could at one point but now its really down on power with 87 and with 91/93 its about where it used to be with 87.  I drive a lot of highway miles back and forth to work and with fuel prices where  they are, being able to run 87 for the long hauls would be great.  With that, I am willing to run it on 91 if it makes the type of power that I think it should. it just feels really weak off the line and at one point when first tuned, it would really get it off the line.  I recently pulled a two wheel trailer to DFW and back and it was horrible on power and mileage and was always in 5th gear it seems.  That was with an empty load.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
