So I have a 2003 5.3 extended cab.  I have always hated ABS and always owned older vehicles without ABS.  Has anyone rerouted their brake lines with good results?  I recently had contaminated brake fluid ruin everything rubber in the system.  I replaced all the soft lines, calipers, booster, and master cylinder.  I just finished the booster/master install today and cant get a good pedal.  I bench bled the master by using 2 1/2"-20 fittings with 1.5" of line sticking out.  Then clear hose tightly slid over the brake line and ran back up into the master reservoir.  The brakes are working now but the pedal goes very far down and is acting like theres still air in the system.  I would like to disable/bypass the ABS unit to eliminate it before chasing my tail looking at everything else.
You can try to lock up the front tires on a dirt road to get the ABS system to activate and try to self bleed. Otherwise you need a scan tool to turn on the ABS system to try and bleed it so you can get a better pedal.
Removing it can be done, just have to make new lines to join things together.
ABS is the nanny I like the best. Here in Texas it gets really hot in the summer. A little shower on a hot day mixed with tar that sits on top of the road would make the back tires dance without abs. I remember vividly prior to abs watching vehicles spinning around on slightly wet roads on scorching days. Especially trucks. The rest of the nannies you can eliminate.
some states with inspections require that the abs light not be on and others don't care. only a matter of time before they check everything thru the data link. I recently had a similar problem but cracking the lines from the master at the abs and bleeding the lines solved it. if the pedal doesn't pump up its probably not air in the system
Kyle
      I don't know how I feel about ABS, I haven't had it come on very much. I would check with the traffic law people there where you live before I did anything. Making your vehicle capable of higher speeds isn't looked at much IME; however should you have an accident and be held liable or some else drives your vehicle and gets hurt you could be on the hook but especially if you defeated or removed a safety feature installed by the vehicle manufacturer. I remember countless times watching guys put big block engines in '66 Mustangs that had 4 lug wheels; wheels and brake systems designed for a car with much less horsepower, installing a significantly heavier and more powerful engine could mean the brake system couldn't stop the vehicle as the OEM would had intended with the OEM engine. The more "go" you put in the more "stop" you have to put in. What you're proposing could have similar implications. Guys with those huge tires and wheels found on monster trucks driving down the highway, those suspension systems and the brake system were not engineered to handle the tremendous forces produced when you increase the size/mass of the tires to those proportions. I would recommend you learn to live with it. Unless you live in a very particular place the ABS doesn't operate all that much; if yours does maybe you should examine your driving technique or style (driving too fast for conditions?) or, you live in Texas like Karnut; I think what Karnut is referring to is not the tar on the road but the slight oil slick from leaking engines, trannys, and axles. When it rains the water and oil create a real slippery condition, it washes off if it rains enough though.
My experience with ABS a f slippery road surfaces had been a bad one.  I literally almost totaled my truck Saturday because abs engaged and made me slide at a 45 degree angle heading for a guard rail.  I had to release the brakes and then the transfer case shifted to 4wd and i could then hit the gas and drive out of the situation.  The main reason i also want it gone is because everything else in the brake system has failed from contamination and im sure the Abs pump is no exception.  Saturday in 1 inch of snow a moderate tap of the brakes would activate abs and send me sliding.
Tires have a lot to do with that. I live in Minnesota and it snows a lot here. I can smash the brakes in the snow with good tires and not slide out of control.
I have disabled the abs on every truck I've  driven in the winter. it will NOT allow you to stop in the snow. some you can just pull the fuse others unplug the module and others unplug a wheel sensor. Of course every truck had a snow plow on it. If you know how to drive in the slippery stuff its more of a hazard than a safety feature. unfortunatly many ppl hop in a 4wd vehicle and drive too fast to be able to stop so it allows them to steer around what they are about to crash in to but doesn't alow you down as fast as controlled braking will. I haven't had any problem with it in my car which is front wheel drive, v8 but I don't drive like a nut in the crappy weather either
  • 3 weeks later...
Remember if you disable any safety equipment to notify your insurance company since they give you discounts for safety equipment and not doing so could be considered fraud in event of an accident.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
