My screen died in my 2018 Sierra Reg Cab radio (w/CarPlay)and I need to replace it. Anyone recommend a good replacement that doesn't break the bank?
Thank You!
Edited by J Alan
If you are just looking to replace the screen... there is a member here who just swapped the screen. There's a thread here somewhere. I'll check my bookmarks in a few. I think it was like 100-300 usd.
Do you wanna keep the stock look or are you open to aftermarket? I think that's really where you need to start. I ripped every piece of stock sound system out as quick as I could but that's just the type a guy I am. Just turned 55 this year and I have never been a stock guy since I was 16 years old. There are so many options available these days
wouldn't he loose all the trucks features if he went with Alpine or other brands ?
OnStar , internet , SAt Radio / HD Radio & everything else ?
Not to mention Rear TV functions if he has the R.S.E / Rear Entertainment
TV & Blu-ray player  , Along with the HDMI connection on the rear of the
center console .
Edited by PAPER
center console .
most can be retained with the proper wire harnesses. I think there is a gentleman on here that does alot of different harnesses to help. also can go over to crutchfield and check with an advisor, they can answer all your question
You can use iDatalink Maestro RR2 Interface Module. If you go to their site, you can match up your truck to see which current Head units they supports. They pretty much support all the options and then some with that module. I was looking at the Sony XAV-9500ES, which they support, but decided, I'll hold off until my OE head unit dies first.. :D
https://www.idatalinkmaestro.com/en/
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 417 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
