I pulled the trigger and purchased my lease on a 2020 Sierra SLT, given a new lease is ridiculously expensive.  But - the ride sucks unless it is loaded up.  Looking for a high quality Rear Shock replacement recommendation?
Bilstein 5100s.
my mother is buying her 2018 Buick Enclave out next Saturday. The dealership has to honor her old depreciation value. So she is buying it for $11k under what it books for now, instead of getting something else that is out of control in pricing.  It only has 36k on it.
good luck.
I posted about this problem with a 22 a few months ago and the conclusion of the forum was to put some weight in it as its the springs not the shocks causing the ride quality.if you do change the shocks and get noticeable improvement please post with what you used as replacements
That is some great input.  So maybe it is a Spring/Shock tuning thing, as I imagine the GM developers tuned the ride with a load, so there is a trade off.  It does have selective ride (3 position knob), and I find ironically it rides better on the "Off Road" harshest setting. But that only controls the Front Shocks, the rear are conventional.  Go figure.  I know my last truck had "Rancho" shocks, but I would think they are harsher than the one's I now have.  I do still have a "Water Bladder" from my 1st 2wd Truck I owned.  Maybe put that in, but then it compromises the use of the Bed.
Your truck does not have any suspension adjustments at all.  That knob only controls traction control and throttle response.  Just put a few pounds in the back of the bed and your ride will settle down substantially.  Trucks are designed to carry heavy loads.  It's hard to make a truck that rides smooth in an unloaded condition without sacrificing loaded performance.
get a piece of steel plate , that way it doesn't interfere with any cargo you need to carry
I think it does have suspension adjustments, as a cable runs to the front shocks.  And this:
CONTINUOUS DAMPING ADAPTIVE RIDE CONTROL The system monitors input from both the road and the truck in real time to help deliver a smooth ride. Every 2 milliseconds, active dampers continuously adjust both rebound and compression forces to counter heave, pitch and body roll. Stiffness rates also change when Sport mode is selected, or automatically when it senses heavy trailering or large payloads.
Rancho's are my favorite shocks. They give the best ride, and they give great flex for off road, too.  People always suggest "bilstein" and others and ive tried those, they make the ride harsh and you feel every bump in the road. Ranchos have always made my vehicles Cadillac smooth, and seem to always last the longest.
You may be right on that.  My last GMC had the Rancho shock option and it rode much better than my current SLT
https://www.summitracing.com/parts/ran-rs55100/make/gmc/model/sierra-1500/submodel/slt/year/2020
1 hour ago, Anon12345 said:
Just buy rancho's and install them and dont look back. Thats how i feel about it, lol.
Oh geez, ranchos are the worst. My experience with Rancho on multiple vehicles is the exact opposite of yours. They ride horrible, rust fast, and blow out in no time.
OP, If you actually truly want Ranchos on your truck, don’t buy them new. Post a want to buy ad, you’ll probably have people lining up to get them out of their garage for cheap. Most replace them pretty quickly.
the 22 that has the harsh ride came stock with Ranchos. put some weight in it and call it a day
My 22 has ranchos and rides so smooth and soft nowhere near harsh like bilsteins are
obviously everyone has a different opinion. I like Monroe Reflex. they have variable valving that adjust to road conditions. I agree with truck man on adding weight
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
