A lot of people on this forum have noted the extended crank/no start issue, but I just started getting something a little different. After taking my 2021 AT4 3.0L LM2 to the shop with a check engine light for NOx efficiency, the dealer completed an ECM update. Every start since I picked it up last week the truck cranks three times longer to start than it did before the update. It is not as noticeable as when the truck cranks forever and fails to start, but it is not right. I have one other confirmed case of this situation from a friend with the same truck, but was wondering if anyone else is having this problem after the newest update? To make matters worse, when the auto stop feature kicks in there is a longer delay than normal for engine re-fire which is not doubt a safety issue when in traffic.  Thanks in advance for your responses.
Most everyone who has the crank/no-start update applied reports that the vehicle cranks slightly longer after the update.
Presumably the checks that are done after cranking begins, but before the injectors are fired is the reason.
Mine seems to crank longer too.
I've not heard anyone else comment about the auto stop/start taking longer.
I don't think mine takes longer for the restart.
Auto restart does a bunch of things different, so I'd not be surprised (but can't verify) if it doesn't do all the same 'pre-start' checks that are done before the first start.
I don't recall anyone ever reporting a crank timeout / start when restarting from auto-stop.
My 3.0 was at about 17,000 miles and 16 months old before the update was applied.
It has never had a crank timeout / no-start.
I guess what I'm suggesting is the longer crank at first start is to be expected.
Messing around with mine, I find I can reduce foot pressure on the brake enough that it restarts, but does not permit the vehicle to move.
It must reach a minimum speed before autostop will activate again, so if brakes pressure reduced enough that the vehicle is allowed to creep ahead to make it start, and then brake pressure again increased to hold vehicle -- it won't re-stop.
I took my 2021, 3.0 L Duramax in due to the crank no start issue. It never popped a check engine light and it’s done it twice in the last three weeks. Dealer performed an ECM update and when I went to pick the truck up today as soon as I started, it had a check engine light for P1098 coolant control valve. Has anyone experienced this code after an ECM update for the crank no start issue.
14 hours ago, silveradosid said:
it is common to get codes after programming has been done , the tech should have checked and cleared codes, this is the procedure from gds2
So i left my truck for another day and they performed another updated they stated it needed after the first update which kicked the check engine light. Went to pick my truck up yesterday and sure enough the check engine was on AGAIN before i left the lot. Dealer is now saying it need the coolant flow control valve replaced....Which as we know it on back order.  Im pissed that I took it in for a crank no start issue with no codes or lights and now Ive had two updates and codes and lights pop after each update. How does a truck all of a sudden need a CCV when it was being serviced for a completely different issue....
This is certainly not what we like to hear, Cody Silva.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2021 Chevrolet Silverado's Coolant Control Valve. To do so, please send an email to [email protected] with ATTN: Cody Silva/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
On 2/9/2024 at 7:56 AM, Mike Bradley said:
IS THERE A TSB ON THE CRANK NO START ISSUE?
There was.
The software solution/update for the LM2 was released November 2021.
If the truck was built after then or if it has been updated since then it will have the revised software.
Edited by redwngr
On my 2022 Refresh what you are calling a longer crank is my normal start every time on my truck. Crank Crank Crank start. Probably three full revolutions of the engine. I think the fix was to take more reading from the Crank Position sensor before starting. Originally it only took one reading and if it missed that the engine would not start.
  • 10 months later...
I think there are two issues. My 21 Sierra was not starting on the first attempt but started on the second attempt at least once per week.  I had the ECM update applied and that issue hasn't happened since. There is another issue that prevents the truck from starting for roughly 30 minutes. That has beppened five times since I bought the truck new. It will show a low battery voltage warning after not starting on the second or third attempt.  Is there any known fix for the second issue? My local dealer isn't very good and won't do anything unless I can give them a TSB number.
We are sorry to hear of these concerns with your Sierra and would like to take this opportunity to learn more and assist as best we can. To begin, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We will watch for your email.
What this video, jump to the 12:00 where it talks about the long crank.
We hope all is well. As stated, our team would like to ensure that we take a look into this further on our end. Do send us an email when you have a moment.
Please know, if you find that you may be in need of assistance with this matter at any time, we are just an email away.
Not sure why GM has decided to change what is covered under their powertrain warranty, but it seems that they are trying to screw over customers. I had the P1098 code pop up on my 2021 GMC 1500 3.0 Duramax at about 58K miles. I didn't realize what it was, but I was unable to get it into the shop for another month (not many shops out here) so by that time it had 67K miles. The check engine light comes on and goes off and sometimes it goes into "engine power reduced" mode. When I took it in, they dealt with a transmission recall issue and said they reset the DCT as per a GM memo. They said it was done so I went to start it with the auto-start as it was cold that day, but it wouldn't start. I got in and started it and the check engine light was on so I drove it back around to the service door and informed them. They kept it for another hour and then stated that the Coolant Control Valve needed to be replaced due to the P1098 code and it would be just under 2K. I asked why it wasn't covered under the powertrain warranty and they stated that GM decided to change what was covered under the powertrain warranty to specifically exclude this problem. They said they worked with GM since I was a first-time customer and GM agreed to "help" cover the cost by paying 10%, leaving me with over $1600 to pay for this known issue. This is not acceptable. I am rapidly losing faith in GM since they would rather screw over customers over a $2K known issue than do what is right. Sub-quality parts are clearly being used, leading to the coolant control valve module failing on so many trucks. The right fix, and the only one that would ever keep my, my family, my friends, and everyone I work with in the military as GM customers is to fix this under warranty.
    250.6k
    tonyb2760
    tonyb2760
  • Who's Online   6 Members, 0 Anonymous, 424 Guests (See full list)
