I ordered a pair of ZRoadZ LED ditch lights with mounting brackets and wiring harness from a distributor around Thanksgiving and they were finally delivered in early March. I took some time looking at You Tube to get some installation hints, I had never installed wiring back in to the cab of a truck before and the instructions were rather vague. I finally had the time this weekend and installed the lights and wired them up on my 2015 2500 HD High Country, should give me a good amount of extra light for when I am driving at night up at the hunt lease
They look good! I'm looking at adding a set. I was looking at the SDHQ mounts with Rigid LED cubes. However, these may be a good alternative. How is the fit and finish of the ZroadZ?
The fit and  finish on the ZroadZ lights, mounts, hardware and wiring harness is top notch. The instructions could be better but these days that is what YouTube is for. I would have liked the wiring to the switch to have been a little longer from Zroadz but I made it work, I could have always spliced on additional wire inside the cab.  Right now I have the switch ziptied under the dash on the left side, right at the bottom front. It works for now until I decide what to do about switch placement that looks decent.
