Hey GM-Truck.com members, I had been visiting the site from time to time when researching questions on the 2022 Silverado models. Good info found here that was helpful when it came time to go shopping.
I eventually decided on a RST after mulling over the Trail Boss a while.
Thanks.
  • 3 months later...
