I just replaced my drivers side AFM lifters after getting a P0307 code. The lifter was definitely collapsed.
When I re-installed the fuel pump, I did NOT have it at TDC. Now when I try to start it, it sputters and is throwing 6 different codes pertaining to open circuits. (P0090,PooC8,P0202,P0204,P0206,P0208.)
I changed all the seals on the injectors.
 My question is, does installing the fuel pump not at TDC affect this? Could it possibly be that simple?
I have been working on this for a week now and am getting frustrated.
Any help is much appreciated.
Todd
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
