Hello gents! Looking to throw some 35's on my 2021 LT Crew Cab 4X4 2.7L and would prefer to not level (it's pretty close to level stock). Any idea if they will fit with trimming?
I am not expert but I would think it wouldn't fit. My neighbor had a 3.5" lift on his and it still rubbed a good bit, even after he pulled off the flaps.
If you were leveled and on stock wheels they would fit just fine, seen it quite often.  Without being leveled though, I am uncertain.
I had them on a stock '22 Trail Boss and they rubbed slightly at full lock.  They're going to rub significantly more on a stock non-TB.
You are going rub especially considering that you don't want to level the truck out. Now if you decided to remove the rear bracket behind your fender liner and pull it back some and cut some out of the front you will gain extra space. Even doing that you might still rub some.
