Just a question when towing my boat.
Best to use Tow/Mode when towing my jet boat, and use Exhaust Brake when going downhill when you want to let the engine slow you down and save the brakes?
Turn the Exhaust Brake off, when not going downhill. Or use the Exhaust Brake all of the time when towing?
Thanks,
I use tow/haul mode every time I'm towing heavy. Starts you off in 1st gear and changes the shift points to keep the RPM's up. If pulling a light trailer, I wouldn't even bother, as it's just going to hurt your fuel economy without providing much benefit.
The exhaust brake only really shines when going down some long steep grades, like in the mountains. I've made it a habit to turn it on whenever I'm putting it in tow/haul mode and just leave it on. It doesn't hurt anything to leave it on, as it only works when necessary.
Thanks for the replay, that helps a lot.
My boat is about with trailer is about 3500 pounds. Worth it to run in tow mode?
Also plan to get a 6-7 ft trailer for yard and tree cleanup.
Edited by gregus73
If your truck is a 2500 or 3500hd and your trailer is 3500 lbs, I would not use tow/haul mode. Won’t hurt if you do, but the shifting will be smoother in normal mode. Try it both ways, and see which you prefer.
Thanks again for all of the assistance. My Suburban and last 2 trucks were 1500s.
First time 2500 and Diesel.
3500 pounds is a light load, considering you can tow 5x more than that. Wouldn't bother with the tow/haul mode. You can still play around with the exhaust brake though. When you are using cruise control and have exhaust brake turned on, it'll automatically kick in to keep you at your set speed when going down a steep grade.
Thanks,
I'd leave both on when towing.  Exhaust brake will put in extra work on the downhills to regulate the descent, but it will still give assistance on flat ground.
FYI ... if you use T/H, turn the truck off and restart it within ~4 hours, it will automatically start up in T/H mode.  However, the same is not true for the exhaust brake.  You must restart it every time you restart the truck if you want it active.
Thanks again for all of the replies.
The funny thing is that at the dealer the 2500s were better discounted than the 1500 Silverados.
1500s were 8k above MSRP and 2500s were $5500 below.
Made more sense to just go with the 2500 with diesel. Plus the 2500 looks so much better to me and room to grow if I ever get a bigger boat.
Edited by gregus73
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
