Hi guys,
got some questions:
I think I’m starting to have issues with afm system. How long can it go? Am I playing Russian roulette?
details:
2019 Silverado custom, 5.3
103000 miles.
started having tick around 45000 (of course after warranty)
I would get valve train clatter occasionally around 2200-2800 rpm not to often (mild acceleration not hard)
last trip I did was with small trailer (5k and towing mode on)  and with cruise control the valves would start clattering every 15 min. I would turn off cruise control and let the clattering stop and resume speed.
now it’s happening a lot now every time I’m on hwy with cruise control.
would afm disabler help now? Or is it too late and should be looking for the afm delete.
is there a way to very one of the valves is bad?
thank you,
randy
14 hours ago, Randy Oreilly said:
Hi guys,
got some questions:
details:
103000 miles.
thank you,
randy
Edited.
Edited by Gangly
  • 4 weeks later...
Update: 6 speed transmission blew before engine. will consider chip the. Full afm delete after transmission issue
For others info:
mileage 105000, light towing, mostly hwy mileage. Transmission fluid changed 45k at dealer. Was about to change again and found a lot of metal.
Edited by Randy Oreilly
  • 2 months later...
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
