My truck shudders at low speeds, generally city speeds from 30/35 to around 50/55 MPH. It is not a constant shudder and usually occurs while cruising, not accelerating. It will stop if I ease of the pedal or speed up a tid bit. Most often than not, it will happen in the 30/35 to 40/45 MPH range. I cannot ever tell, but to me, it seems like it happens when it is between shifting or something?  A mechanic friend suggested it may have something to do with the torque converter? Although I can pull 'em and put 'em back in. I am not much more than a DIY shadetree mechanic that works on my own. This is irritating as hell.
How many miles? And what transmission? 6 speed or 8 speed
I have the same problem, I bet if you watch your DIC you will find it happens at those speeds when you are in V4 mode.  Will happen in V4 mode at those speeds usually around a slight incline.  Press the gas pedal a little more and it goes into V8 mode and disappears.  This happened really bad while towing my camper and lead to a transmission replacement at 98,000 miles (most likely not the problem).  2 years later this seems to have come back with the symptoms you described.  Right now it is more of a buzzing then a shudder but when it was shuddering was when I was pulling my camper.
My 2017 Sierra Denali is also doing the same thing, usually notice it after going around a corner just after I lift my foot off the brake and start slowly accelerating. Perhaps it's going into second gear without enough fluid pressure to complete the shift in short order. At first when it started doing this, I though there was some "washboard" in the roadway, but it seems to be happening in every corner. I have 26,000 miles but the warranty is long gone. I'm thinking about selling it before it breaks and leaves me with a big bill....
As far as the motor being in 4 cylinder mode, the only time mine is in 4cyl. is when I'm coasting down a hill. The 4cyl. mode doesn't have enough power to get out of it's own way, total joke....
Check with your dealer to see if you can still have the TSB done switching to the Mobil 1 Blue Label fluid.
Does not hurt to check, would save you money, it did work on my truck to get rid of the shudder.
Dear All,
I have Denali 2014 pickup and facing the same issue in the transmission between 1500 -2000 rpm. anyone resolved this issue and can share his experience please?
I took my car to GMC dealer and waiting for their investigation result and will update their observations.
Regards,
Abdulla
11 hours ago, Abdulla Muhsen said:
Dear All,
Regards,
Abdulla
6 Speed?
If so, probally your torque converter is going to need to be replaced.
Seems owners are obsessed with motor oil changes every 3,000 miles but when it comes to the transmission fluid, it's OK to ignore it.
The oem's like GM spec out fluids but they get supplied by the lowest bidders that just meet spec. Like almost everything manufactured by low bidder, they use the cheapest (and often lowest priced) additives to meet the low bid.
Example.....this pertains to GM 8-sp transmissions
GM Dexron HP
"The base stock of old fluid (19355656) has the ability to attract low levels of moisture, which can cause degradation of the coefficient of friction of the fluid. The new fluid (19417577) has a new GTL (Gas to Liquid) base stock that is able to tolerate more moisture. Shuddering transmissions and torque converters have been recovered with the new fluid. New transmission fluid tests have been developed due this issue to prevent it from occurring with new transmission fluids."
NOTE-GTL fluid is an improvement over the existing fluid but GTL base stock is still a compromise over using a better PAO base stock which is more expensive.
Edited by elcamino
23 hours ago, Abdulla Muhsen said:
Thank you JimCost2014 for your advise. will replace the torque converter and update.
Regards,
Hi,
I replaced TC and the problem resolved completely. The shuddering sound gone and shifting between speeds became more smooth.
Thanks  JimCost2014 again for your advise and information.
Regards,
Edited by Abdulla Muhsen
correction
I have posted a similar answer to this type of thread before. On my 2014, I initially changed the fluid around 65k miles along with the filter. The fluid looked like chocolate. I have since changed 1 gallon of fluid every 15k miles. I use a hand pump and pull the one gallon of fluid out of the dipstick and replace it with a fresh gallon of fluid. I am at 118k miles. The fluid looks brand new now. I don't know whether this will allow my transmission to live longer or not, but for the price of one gallon fluid, it's a no brainer. It takes me 20 minutes to the the job and I feel like I have done something good for my transmission.
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
