I installed the larger GMC splash guards on my truck. I like that these cover the width of the tire now, but they don't seem to be made as sturdy as the original ones. And doesn't use one of the screw anchor points on the back set.
They do look good!
Wonder if they do that to maintain flexibility if they get hit (tree stumps, rocks, etc.)?
I've got the standard version on a '22 chevy 3500HD.  Still get plenty of muck up the doors and on the door handles, even with the stock tires.
Looks like what you've added will help with that.
I'm thinking of going aftermarket adding on the stock ones.  To get a bit more protection for the doors, and the rockers/rear quarters.
Something like these:
https://www.sharptruck.com/truck-hardware-gcr202k-bk
Those should definitely stop most everything. Driving around through some of the muddy streets after the flooding we had last week had me cringing hearing the mud slinging up the side of my truck.
I wanted the gm guards but I was concerned that they didn't come down low enough to block the mud and rocks slinging up on the truck.  I went with the husky guards and have been really happy with them.  I was afraid at first that they were gonna be too flimsy but they don't seem to be and the flex in them was much appreciated when I had to jump a tall curb and the concrete caught one while going over.  I checked the guard afterward and couldn't tell it had hit anything.  They look good too.
Edited by c0wb0y84
I've been looking for a long time for good long flaps and thinking of going with the Duraflaps. They are pricy though!! Anybody have them or know of anybody with them?
I bought Husky kickback mudflaps month's ago.  Haven't put them on yet as I'm still on the fence as to whether they will take away from the look of the truck too much.  Although the knicks on the paint from the tires is definitely a bummer
I put the Husky splash guards on and I like them so far, time will tell how they hold up but they seem to be pretty solid and I like how they match up with the factory molding.
Some good options above.  I don't think all of those were available two years ago.  I installed the larger GM flaps right after purchase and quickly decided they didn't give the coverage I wanted.  My hack solution in pics.  They keep stuff off the truck.
Edited by Wxman
Nice job!!!
I was debating whether to add on to the GMC wide flaps but didn't know if they would look funky but I like yours. How far did you hang them down past the OEM's.
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
    • Just pull the inside door handle.  It has mechanical override to the lock.
    • Got to have those sliding doors. One of my favorite things about a minivan. The Kia does a good job of making a minivan look like an SUV. I may do a Toyota next. I want the awd option.
    • I took my 24 Sierra Denali 4wd in at 37,000 miles. Had the mileage maintenance checks done, asked them to change out the two limited slip differentials, including the limited slip additive, and change out the transfer case fluid. They rotated my tires, verified my shocks weren’t leaking, and whatever minor checkouts that were on the list for 37,000 miles. About three hours later, they charged me $600 and sent me off. I was considering having the 10-speed transmission serviced, but between the posts on this forum and previous experiences with transmission failures after a fluid and filter change, I decided against the tranny fluid changeout when the service advisor told me it would take about 3 hours and cost about $500. After growing up working in three different full-service gas stations, I know to stay far away from flushing machines connected to any automatic transmission. I don’t meet the severe duty schedule, but I may follow the 45,000 mile tranny service, unless  i see more problems from doing so on the forums. I expect I will want to watch the entire procedure. The various utube videos do a decent job of showing how much time and attention should be taken for a correct fluid &filter replacement, so witnessing the procedure seems something I should do. Trust but Verify🥳 Otherwise, I’ll follow the owner’s manual recommendations, whatever they are.
