I have a 2020 Silverado HC 1500 with the 6.2L and, I think it has the 9.76 rear end.  I am considering, at least, adding a rear locker.  I'd like to use a factory option locker, has anyone done this and have some insight into the process?
Edited by AEmedic
High Country has the rear G80 locker as standard equipment.
Edited by elcamino
Not truly a locker. It's a mechanical limited slip. It doesn't work above 35mph.
Is there an actual Locker that has been offered in our trucks?
The ZR2 is the only truck with an electronic locker front and rear. So far nobody has been able to figure out if it is possible to retrofit into other trucks.
it's a locker, just needs ~100 rpm difference in wheel speed between the wheels and it locks in, disengages on it's own also...likely when the wheels stop and unloaded it pops out?, I forget the parameters when it will disengage, it operates automatically, I'd definitely look at a manual e-locker(zr2) or the true-trac limited slip as preference to the g80 (all of them are eaton), but you at least have a locker that will likely only engage when you actually need it so it's not a terrible option, I would take the g80 over any of the conventional clutch pack type mechanical slip differentials, the only one of those worth having is the true-trac(no clutch plates to service all the time), a lunchbox locker would also be something I'd consider so if anyone knows what will fit these trucks any info appreciated
On 2022 1500 WT and Custom the G80 rear locker is an available option
On all other 2022 1500 LTD Silverado trims the G80 is standard.
Refreshed 2022 ZR2 gets the front and rear E-lockers, other trims above WT and Custom get the G80.
Similar with the Sierra
AT4X gets the G93 and G94
Pro trims have available G80
All other trims G80 rear is standard
9.76" appears to be on NHT only
Edited by redwngr
Incorrect, it is a true locker.  It works just fine above 35 MPH, hell I've been locked at 70MPH, it just has to initially engage below 35 mph.  If you lock it up at 5 mph then it will stay locked, regardless of your speed, until you do a significant turn maneuver which releases the armature.  When it locks, it is a 100 % locked, mechanical engagement and it will not slip.  I'm not sure where you got your information from, but it isn't accurate.
On 9/5/2022 at 5:26 PM, Gangly said:
redundant
Edited by Gangly
    jgaudet99
    jgaudet99
  • Who's Online   1 Member, 0 Anonymous, 484 Guests (See full list)
