I have had this truck 2 months and from day one the infotainment system has had this issue. when I make or receive a phone call my system will show me still in a call even after I have hung up.  I have been to the dealer and I have been on the phone with GM but no one seems to want to help or they have no idea what's going on. this truck is brand new with less than 2000 miles on it. and I am looking for any solution to this problem. anyone with any insight on this issue would be welcome.
Join the club, I have a 2019 and it's been doing it since owning, and every trip to dealership and no solution. Now I'm out of warranty and will get robbed trying to solve a problem that seems to be larger than a small group.
This is certainly not what we like to hear, scott slagle.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle's infotainment. To do so, please reach out to our Connection Center Team (CCT) for further assistance. They can be reached via phone at 877-558-8352, Monday-Sunday from 7AM-10PM ET. Be prepared to provide the advisor with your contact information and the last 8 of the VIN. This information will be needed for the advisor to locate your account in their system.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
In the same boat here. I have a 2019 Trail Boss like EagleRising and have the same issues as they. I never know what my infotainment center is going to do. Sometimes locks up, unable to change stations. Other times sound but no screen. Sometimes nothing at all. There have been several times when the radio would not go off when I got out of the truck. Walked away wondering if the battery would be dead when I returned. Trips to the dealer only resulted in being told it needed an update. Problem keeps coming back. WORST system I have ever encountered.
Since the problem seems to occur during or after phone calls, Make sure your phone is hooked up right to the car's Bluetooth system. Try unpairing and pairing them again for a new connection. And just in case, see if your phone and the car's system get along – compatibility matters.
Oh, and if your infotainment system lets you clear the cache. It might sort out any little hiccups.
3 minutes ago, ramipologan said:
Same issue in my 2016 GMC 2500.
After a call, no more bluetooth music til restart.
Didn't use to be like this.
Not the same as your radio is completely different from a 2022 or a 19-25 for that matter.
    Paul8556
    Paul8556
  • Who's Online   5 Members, 0 Anonymous, 596 Guests (See full list)
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
