Hello.  I am attempting to switch out my manual tailgate lock for a powered tailgate lock.  I have switched out all the hardware in the tailgate and now I just need a power wire for it.
So what I need is a signal wire saying the truck is locked via the fob.  I can use this signal wire for a relay and run the wires to the back of the truck.
I tried looking at the door lock switch as this functions properly. (Works all the time except when you hit lock of the fob, then its disabled). But i saw 4 wires at the switch.  2 seemed to be 12v and 1 seemed to be ground.  How do the door lock switch wires work and can i use them to get a signal wire?
Or anywhere else i should get this signal wire?
Thanks
I do not know the current wire schematic for door locks, however, there are 2 spots you can tap into, one is on the foot panel by the door and the other is the wiring harness up under dash. Im sure someone can chime in with the correct wiring color. Can you post your year model and trim level as this may help whoever is looking it up. I did this exact thing on my 2016 and it was super easy once I knew which wire to tap.
Thanks for the reply.  Its a 2020 Silverado LT but i swear its a base model 🤣.
  • 5 months later...
On 10/28/2022 at 4:37 AM, Jaynen Reibling said:
Well I did manage to get an OEM GM tailgate release popper to work.  Was quite the nightmare but it seems to be working.
And how did you get the power?  Please share for us dummies.
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
    • I just purchased a 2004 Tahoe with 148,******. I used to have a 2006 Suburban that had the push button Auto 4X, 2Hi, 4Hi and 4Lo. When checking out this truck I noticed it had push button but didn’t focus on it. After the purchase when driving home, this is when I noticed it was different and after a little research found out it has the AWD stabilitrak system. I don’t live in an area that requires AWD. I bought the truck to start a new adventure in life with off roading, now that the kids are all grown up. I purchased the truck knowing it didn’t have the G80 rearend but plan on re-gearing to drive on 33s or 35s and upgrade with a rear locker and still be able to tow when needed. Blah Blah Blah Anyway I know am thinking about converting the stabilitrak  to Z71. I know I will have to replace the transfer case. So now the information gathering stage is happening to see if it is worth it. Is the front AWD stabilitrak differential different when compared to a non-AWD front diff? Will I need a completely different front differential or can it be converted? What else should I be considering? I did see something in a video for GMT900 platform with removing the ABS fuse that disables the stabilitrak and turns the truck into a 2 wheel drive. Would that work in the GMT800 platform?
