In my 2022 that I just picked up, I notice that I get zero notification of texts when I'm not in the Android Auto screen.  Every time you start the truck you have to manually select the Android Auto icon.  That part works fine.  But I'm told that with CarPlay you still get text notifications if you're on the native Nav or Radio App.  It would be nice to not be stuck in Android
Auto 24/7.  Is that just how Android Auto is or does my truck need an update or something like that?
there is s a setting (must be done in park) to allow what to notify
a text
subject only
et.
a text
subject only
et.
That's a setting in the Chevrolet UI or in Android Auto?
  • 2 years later...
My last truck was a 2019 Silverado LD/LT. It would always notify me when text messages came in and would play them aloud as well. My current truck (2023 Silverado LT) says I need an internet connection in order to hear my text messages aloud. What a bunch of crap! I have tried everything in the settings and nothing has helped. Is this the bottom line?? (I have an android phone, Samsung S23+)
My 2020 won't give me any notification of any kind. I do get phone calls. Unless I'm using the phone as a source for playing music and such. So I'm I looking in setting for this to turn on or pick?
    LCH14
    LCH14
  • Who's Online   4 Members, 0 Anonymous, 1,647 Guests (See full list)
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • 对于 8L90 来说,198°F 并不算异常高,所以我认为仅仅是温度并没有造成这个问题。 由于卡车停放几天后一切恢复正常,因此在认定变速箱本身发生故障之前,我会先检查是否存在间歇性的电子或液压控制问题。 我首先会扫描变速箱控制模块(TCM),而不仅仅是发动机控制模块(ECM)。通用汽车的变速箱可以存储厂商特定的故障码或历史故障码,这些故障码不会触发发动机故障灯。 我会检查: TCM历史记录和待处理的DTC 指令装备与实际装备 管路压力 换挡电磁阀状态 液力变矩器离合器(TCC)打滑 变速箱油温 如果再次发生这种情况,请尝试在重新启动点火开关之前捕获数据,因为有些间歇性故障在重新启动后会消失。 使用支持通用汽车变速箱全面诊断的专业扫描工具,这项工作就容易多了。例如,Foxwell NT809BT可以访问变速箱控制模块 (TCM),读取制造商特定的变速箱故障代码,并显示基本 OBD-II 读取器无法提供的实时变速箱数据: https://www.foxwelldiag.com/products/foxwell-nt809bt 希望只是间歇性的控制问题,但在更换任何部件之前,我肯定会先读取变速箱控制模块(TCM)的数据。
    • The 92-95 SCPI spider injectors are notoriously problematic and hard to source new replacements. I’d pull the intake manifold first to inspect cracked lines and brittle plastic legs before dropping $350 on a rebuild. The 1.5 OBD system only offers limited data, no misfire tracking, which is normal for this 1995 model. Enjoy the project!
    • Yea a fluid change is in order here. Honestly, your transmission didn’t even get hot. During the summer in stop and go traffic I’ve seen my 8l80 get up to 216 and it was still shifting smoothly.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
