I’m new to the forum so apologies as this has probably been discussed. If so could you direct me to that post?
I have a 2021 - 3.0 Duramax 4x4 with factory, 265/65R18 tires. It’s getting time for new tires. I’m considering a one size up, 275/65R18. Has anyone done this and had a significant decrease in MPG’s? (Also with a leveling Kit?) Any issues with tire scrubbing at full turn?
I enjoy having a full size truck that does get good fuel mileage and don’t want to adversely effect it.
Thanks
I think you could go up a size without any noticeable difference. I have a '21 Trail Boss. The factory tire size is the same as yours. Granted, the Trail Boss has a factory 2" lift, but I was able to go up to 295 70 18 Falken Wildpeaks with the stock suspension.  My speedometer is 2 mph too slow with the new tires and gas mileage has remained the same.
I have a 21 1500 with the 3.0L Duramax as well.  I installed a 3"Cognito coilover in the front and 1"block in the rear and have 35x11.5 on the stock 20"wheels.  I noticed a decrease in my MPG with my best pre lift being around 28 and best now is like 25 (i drive a lot and mostly see 23- but I do drive 80!)  I also took off the front air damn so there is a decrease in aerodynamics as well.  I recalibrated my speedometer with the Rough Country speedometer calibrator as well so the numbers are fairly accurate.
I have a 20 RST in 2wd. I used to average 29-33mpgs with the 265/65. I then added the Rough Country 2.5" lift and put 275/70/18 tires on my stock rims. I've driven about 15,000 miles with them and my average is now 27-29mpg. I noticed that the weight was the biggest contributor to the mileage, as well as speed. When i went to buy my tires (bridgestone dueler a/t revo3), i chose them because they were one of the lightest and quietest, but still had an off-road look.
If i keep my speed down from 70 and lower, i'll get good mileage (back to low 30's). Anything of 70 now and it drops to 26-28.
Thanks
That size is a factory size on the Diesel Off Road Pkg that's available, and the 20s are a 33 inch tire so you won't have any rubbing concerns on anything up front.
As for MPG hit, a couple factors.  The tread you pick can change it (highway vs. AT vs. MT), the added weight results in more rotational mass too.
Thanks for the response
Thank you for the response
Thanks
Thanks
  • 6 months later...
Sounds like I might have an issue or something. My RST is stock with the babymax and the best ive seen is 25.
Are y'all using the 25/50/400 mpg calculator in the dash options or doing a manual old school math calculation?
  • 5 months later...
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • $4.26 85 oct
