I’m new to the forum so apologies as this has probably been discussed. If so could you direct me to that post?
I have a 2021 - 3.0 Duramax 4x4 with factory, 265/65R18 tires. It’s getting time for new tires. I’m considering a one size up, 275/65R18. Has anyone done this and had a significant decrease in MPG’s? (Also with a leveling Kit?) Any issues with tire scrubbing at full turn?
I enjoy having a full size truck that does get good fuel mileage and don’t want to adversely effect it.
Thanks
I think you could go up a size without any noticeable difference. I have a '21 Trail Boss. The factory tire size is the same as yours. Granted, the Trail Boss has a factory 2" lift, but I was able to go up to 295 70 18 Falken Wildpeaks with the stock suspension.  My speedometer is 2 mph too slow with the new tires and gas mileage has remained the same.
I have a 21 1500 with the 3.0L Duramax as well.  I installed a 3"Cognito coilover in the front and 1"block in the rear and have 35x11.5 on the stock 20"wheels.  I noticed a decrease in my MPG with my best pre lift being around 28 and best now is like 25 (i drive a lot and mostly see 23- but I do drive 80!)  I also took off the front air damn so there is a decrease in aerodynamics as well.  I recalibrated my speedometer with the Rough Country speedometer calibrator as well so the numbers are fairly accurate.
I have a 20 RST in 2wd. I used to average 29-33mpgs with the 265/65. I then added the Rough Country 2.5" lift and put 275/70/18 tires on my stock rims. I've driven about 15,000 miles with them and my average is now 27-29mpg. I noticed that the weight was the biggest contributor to the mileage, as well as speed. When i went to buy my tires (bridgestone dueler a/t revo3), i chose them because they were one of the lightest and quietest, but still had an off-road look.
If i keep my speed down from 70 and lower, i'll get good mileage (back to low 30's). Anything of 70 now and it drops to 26-28.
Thanks
That size is a factory size on the Diesel Off Road Pkg that's available, and the 20s are a 33 inch tire so you won't have any rubbing concerns on anything up front.
As for MPG hit, a couple factors.  The tread you pick can change it (highway vs. AT vs. MT), the added weight results in more rotational mass too.
Thanks for the response
Thank you for the response
Thanks
Thanks
  • 6 months later...
Sounds like I might have an issue or something. My RST is stock with the babymax and the best ive seen is 25.
Are y'all using the 25/50/400 mpg calculator in the dash options or doing a manual old school math calculation?
  • 5 months later...
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
