Hello everyone I’m new to this forum so I hope this is an acceptable topic.
I have a 1996 K1500 4.3L and I’m having heating issues. Started off with no heat and ended up needing a thermostat. That worked for a winter and now we’re back again. I determined the heater core was not allowing fluid through so I put a new core and hoses in and confirmed fluid is flowing as well as another 195° thermostat just for good measure but the truck still has questionable heat. Where should a guy look next? It runs pretty consistently at 170°F despite the 195° thermostat.
Are both heater hoses about the same temp?  if not the core is restricted still. if so the blend door or actuator is probably stuck or not working. does the truck have a/c and electronic control or no a/c cable control?
What brand?
If not OEM then Motorad is one to look for.
sounds like there's still a restriction in the coolant lines. maybe in the fittings for the heater hoses on the engine? Does the return line go to the radiator or the water pump? Inlet temp should be the same as engine coolant. You could reverse flush the heater core with a garden hose just to make sure it's clear
We replaced the inlet and return lines completely except for the metal tube section in the middle which we cleared with a wire bottle brush. If there is an obstruction it would have to be within the water pump itself but I pulled the outlet line off and ran it and the flow seemed as free as I would expect it
The supply line originated in the block and terminated at the water pump
you got your self a real head scratcher! you replaced the Fitting on the intake manifold ? The oem fitting was a quick connect aluminum deal that was prone to corrosion. Even if engine temp is only 170 you should have good heat. as stated if the heater circuit is clear the inlet should be same temp as engine and return only a few degrees cooler at 1200 rpm
We sure did, the fitting snapped when we tried removing it necessitating it’s replacement. It sure is a head scratcher, we’ve tried everything. And it’s something that happened between this year and last year because the heat was stellar last year
some radiators have a nipple for the return line that would be capped off where yours returns to the water pump, if you have that you could switch the return to there and cap the water pump nipple and see if that helps
Right side just below the rad cap, not all rads have it. if you are 100% sure the core and lines are clear I think the only other thing it might be is that the passages in the intake manifold may be blocked by corrosion which would entail removing the intake to check and clean although you maybe able to check with a borescope camera if you drain some coolant
Either Lisle or KD makes a heater flushing attachment for a garden hose that has an air fitting on it to give a blast of air along with the water. I added a water shut off to mine  to save going to the spigot to shut it off
when you removed the return line from the water pump there should have been no flow from the water pump nipple with the engine running and strong flow from the return line. A defective heater core is a VERY remote possibility BUT if there is good flow the lines would be the same temp so probably not that
Well I replaced the heater core and lines so that’s already been eliminated and there is good flow coming from the return of the heater core so I am starting to suspect the issue is on the return side
I have never seen a problem in the water pump but I guess anything is possible. Its not a hard pump to r&r  to check it.  No nipple on the rad I take it.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 519 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
