Seems that for the last 20 or so years whenever GM comes out with a new HD truck or an MCE update to an existing HD truck rumors start that GM will finally go to some sort of E-coat and get rid of that messy wax coating they have used since 1987.  The 2024 update is no exception, I have heard that the goo is finally gone and new E-coat equipment has been installed at Flint (funny, I thought the frames were vendor supplied).  The wax coating (actually called Nox-Rust) first appeared on the GMT-400 trucks in mid-1987 and by the mid-90's Ford and Chrysler were using it as well.  I always thought it did an adequate job of protecting the frame and liked the fact that it's easy to touch up (the material is available in spray cans) but it is messy, dirt sticks to it like crazy, and it needs to be touched up A LOT under certain conditions.  On the other had I would have to say that outside of certain Toyotas pickups Ford F-150's seem to me to have the most frame rust issues, and they have been E-coated for years.  Nonetheless, judging from comments on many pickup truck forums, many GM truck fans would like to see the wax replaced.  Both Ford and Chrysler dropped the wax years ago on their full size trucks, and GM does not use it on the Colorado/Canyon or any medium duty cab and chassis models.  So, what is the story?  Why has GM stayed with wax dipped frames for so long on certain trucks?  Will GM change to E-coat?
My 22 is my first dipped frame truck so we will see how it goes. The last GM truck I owned was pre dipped frame actually!
it would be cool to hear more stories on it.
I did find a cool picture of HD frames online though.
My 2020  wax frame is still doing well.  I have driven it very limited though when road salt is spread.
my 2002 1500 was abused and rarely washed underneath...the frame only had surface rust and some wax areas were still there.  The cab corners and rockers were another story :(.
the part that really rusted out was the rear axle.
my wifes 2006 Honda civic frame looked pristine up until 2016 when we sold it. Thats Midwest salt roads and all.   Her 2015 CRV and later 2020 CRV were also pristine.
Whatever Honda does (or used to do) to keep their frames so nice I wish was emulated by GM.
However, I did see a few gently used newer model hondas that came from Michigan that looked pretty bad.  Probably never had an undercarriage wash
Edited by greatmizzou
I don't like having to work under the truck, and feel for the GM mechanics who have to deal with the waxy mess.  Something as simple as adding a front hitch to a truck with less than 5K miles leaves the installer looking like they just worked on a 1950s diesel bus.
Living in a state that salts the roads pretty heavily, I don't see an advantage to the wax.  I see just as many rusty GM trucks as I do Ford & Dodge.  It just doesn't seem to be an advantage in that regard.
Overall I'm not a fan.
It would be great of GM stepped up to e-coating.  The new paints with rust converter/preventer do a good job of maintaining an e-coated frame, without all the mess of the wax.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
