Have a 2017 sierra 4wd. Pulled the tarns pan to change fluid and filter because I had a shudder. Pan was full of metal. So I took the pan to a shop and they are saying I need a new torque converter and to rebuild the trans because it most likely ate up the pump. Does this sound right or is it just a shop trying to get over on me ?
How many miles? 6 speed?
Sounds correct. The torque converter is the weak point on these 6 speeds. I would recommend going to the 6L90 torque converter. Here's  a good info link
https://nextgendiesel.com/blogs/transmissions-101/general-motors-6l80-e-6l90-e-transmission-problems-solutions
Edited by rav3
94,000 miles and yes 6l80. He says there are upgrades he will do while rebuilding it. Like billet torque converter and doing away with the thermal bypass
Yes, take their advice about the thermal bypass. Make this transmission run cooler like the old 4 speed autos did. That was the first thing I did when I bought my '17 & well as the Range AFM delete.
Your miles sound about right from what I see & read on the internet. I'm curious on what their cost is for this.
For sure prepare for a new transmission install.
these transmissions are Pos
Get the new GM with warranty and upgraded parts that don’t break.
I paid 5300 total
i was luckily I got 120k miles from my original.
New transmission mucho better.
just suffering from almost 2 mpg less than old.hope this changes. My average used to be 16.5 now it’s 15 ish
good luck
my mods :))
ac system
starter
radiator
transmission
Seat switches
axle joints
soon new booster brake pump
I got it rebuilt with everything changed that’s known to be a problem. I was getting 16.2 right after I got it back. It’s back up around 18.3 now. I just replaced the vacuum pump
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
