I have a 2017 RCSB that's lowered 4/6 with a MaxTrac kit and 22s. I also installed solid end links when I lowered it. What can I do to make the truck corner better and have less body roll? Just a bigger front sway bar and adding a rear sway bar?
Edited by LowRado17
12 hours ago, CamGTP said:
A rear sway bar will help a lot.
A rear sway bar? I feel like most of the body roll is coming from the front. Any suggestions on a company that makes a rear sway bar?
Change your bushings to poly, add a wider tire, beefier front sway bay. If you did drop shocks, look into a stiffer spring and shock to replace that. If you used A Arms drop, a stiffer spring and upgraded shock.
Like sharkey said, poly bushings, change your wheels to something smaller and lighter with wider tires and beefier sidewall. You can call company like Viking to get a custom shock and spring/ coil over combo. Hellwig make some sway bars for front and rear. Also make sure your control arms and end links are leveled and not already at a steep angle. As for the rear you can get a traction bar to prevent axle wrap and keep it more stable.
On 1/14/2023 at 7:35 AM, LowRado17 said:
Checked out the Hellwig sway bars...holy crap they are expensive.
Yeahhhhhh. At that price mind as well get a custom one….  I bought one 3 years ago for $220 for the rear and like $250 for the front.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 1 Anonymous, 621 Guests (See full list)
