Your refrigerant is low. Your symptoms all highlight this. Whether you have an actual leak or have just lost the original charge over the years (about .2-.3 oz per year decay is a thing) remains to be seen. You can connect a gauge set to verify, but you'll really need to evacuate, recharge and monitor for a leak.
Ain't nobody got time for that. The code numbers are sufficient. Google, service info, Chiltons, will all easily elaborate on the definitions. Anyone thats been working on cars for a hot minute will know these very common, as well as global OBD standard, codes with not much else given.
Â
Â
You have a wiring issue, as P0449 is a circuit fault. Focus on finding that, and the other two DTCs which are rationality based, will likely be resolved too.
Register a new accountSign in
