Greetings. I just recently (last couple of weeks) picked up a used 2019 Silverado LT 2wd.  I’ve noticed that the auto start stop has never activated. I’m not getting any error messages and I don’t have a check engine light. I’m guessing the battery may be the issue. If the battery is from the factory, it’s probably just getting old. If the previous owner replaced the battery, maybe he didn’t replace it with an AGM battery.  I posted a couple of pics of the battery, just wondering if anybody can tell if this is the original battery or if it looks like a replacement. I’m not seeing any brand labeling on the battery, just the warning label on top.
Edited by MadMatt3883
Added text.
7 hours ago, AntonyU21 said:
It is recommended to ask a professional mechanic
I’m not spending money to fix this. If it’s an easy fix I’ll do it, otherwise I’ll leave it alone.
1 hour ago, silveradosid said:
battery has nothing to do with the auto stop, start. previous owner might have an auto start stop delete installed in the truck
Are you talking about the aftermarket cable installed behind the switch?
Have you ever checked to see if the truck has an aftermarket tune. I'm betting thats your answer
Actually, the battery has a lot to do with the auto stop/start.  If the computer detects that the battery voltage is low, it will not allow the auto stop/start to function.  This has happened on my Silverado and Traverse.  Both times I had to have the battery replaced.  Problem solved.  One way to test, which I did on the Traverse, was to connect a battery charger to the battery and let it charge overnight.  Then for the next several days the auto stop/start worked.  After that, it quit working.  After a few weeks of driving it around and it wasn't functioning, I took it to the dealer who confirmed it was the battery.
I know a lot of folks on here hate the auto stop/start, but I look at it as the canary in the coal mine.  When it stops functioning, there is an issue with the electrical system.  Could be the battery, could be the alternator, could be the current/temp sensors, etc.  Just my opinion....
It could also be like the others have posted above, the previous owner did something to disable it.
Edited by PhilB
No. What type of ODB scanner would I need for that?
My money is on the battery. I was hoping someone would be able to recognize my battery as being factory or not factory. When I have time I’m going to take it to autozone and have the battery tested.
Edit:  pulled the top cover off. Factory battery. Now I have a check engine light after disconnecting the battery lol.
Added pic.
If you've exhausted the battery and it's not the cause,  you'll need to find a tuner to look if the truck has been tuned. The dealer can also look at the tune counter and tell you. Simple obd scanner won't tell you anything.
When I get a chance I’m going to test the battery.  That battery is 4 years old now.  I’m in south Texas and down here car/truck batteries suffer from early deaths due to the heat.
Could have been a loose connection that corrected itself when you removed and reinstalled the battery cover.  Just a thought.  IIRC, there was something about the bolts that hold the connector board in the battery cover that needed tightening.
Keep us updated.
Here is the entire possibilities list of why the auto stop would disable.  I bolded a few candidates that are either somewhat obvious reasons it wouldn't work, and some not so obvious inhibiting reasons.  The auto start disable list is about identical.
I don't see where these trucks use it per the description and operation, but some of the earlier stop/start that GM used had some sort of an internal timer counter or something that the dealer can go in and reset.  Chances are if these use the same thing, you pulling the battery reset the counter.
Autostop Disable Reason - Transmission Range
Autostop Disable Reason - Passenger Compartment Heater On
Autostop Disable Reason - Driver Exited Vehicle
Autostop Disable Reason - 12V Start Counter Exceeded
Autostop Disable Reason - Vehicle Inclination
Autostop Disable Reason - Remote Vehicle Start Request
Autostop Disable Reason - Acceleration Request
Autostop Disable Reason - Transmission In Reverse
Autostop Disable Reason - Reduced Engine Power Active
Autostop Disable Reason - Ignition Switch Start
Autostop Disable Reason - TCM Request
Autostop Disable Reason - System Optimization
Autostop Disable Reason - System Voltage Low
Autostop Disable Reason - Engine Coolant Temperature Out Of Range
Autostop Disable Reason - Catalyst Test In Progress
Autostop Disable Reason - HO2S Test In Progress
Autostop Disable Reason - Misfire Test In Progress
Autostop Disable Reason - Catalyst not at Operating Temperature
Autostop Disable Reason - Intake Manifold Temperature Too High
Autostop Disable Reason - Engine Speed Test in Progress
Autostop Disable Reason - MAF sensor Test In Progress
Autostop Disable Reason - MAP Sensor Test In Progress
Autostop Disable Reason - Engine Oil Temperature Too High
Autostop Disable Reason - Engine Stop/Start Test in Progress
Autostop Disable Reason - Engine Coolant Temperature Test In Progress
Autostop Disable Reason - EVAP System Test In Progress
Autostop Disable Reason - Fuel Injector Test In Progress
Autostop Disable Reason - Fuel Pressure Test In Progress
Autostop Disable Reason - Fuel System Test In Progress
Autostop Disable Reason - Parking Maneuver Detected
Autostop Disable Reason - High Engine Rotating Torque
Autostop Disable Reason - BARO Pressure Too Low
Autostop Disable Reason - Fuel Temperature Too High
Autostop Disable Reason - System Malfunction
Autostop Disable Reason - Turbocharger Temperature Too High
Autostop Disable Reason - Hood Ajar
Autostop Disable Reason - ECM Request
Autostop Disable Reason - Run/Crank Not Active
Autostop Disable Reason - Minimum Engine Run Time Not Met
Autostop Disable Reason - Control Function Active
Autostop Disable Reason - Auxiliary Transmission Fluid Pump/Accumulator Not Available
Autostop Disable Reason - Engine Coolant Temperature Out of Range
Autostop Disable Reason - Invalid Data Received
Autostop Disable Reason - Vehicle Speed Too High
Autostop Disable Reason - Transmission Fluid Temperature Out of Range
Autostop Disable Reason - Brake Pedal Released
Autostop Disable Reason - Brake Booster Weak Vacuum
Autostop Disable Reason - Accelerator Pedal Pressed
Autostop Disable Reason - A/C Request
Autostop Disable Reason - Low-Voltage Battery Voltage Low
Autostop Disable Reason - Low-Voltage Battery State of Health Low
Autostop Disable Reason - Low-Voltage Battery State of Charge Low
Autostop Disable Reason - Low-Voltage Battery Discharge Current High
Autostop Disable Reason - Intake Manifold Weak Vacuum
Autostop Disable Reason - Engine Speed High
Autostop Disable Reason - Wheel Slip Detected
Autostop Disable Reason - Vehicle Speed Threshold Not Reached
Autostop Disable Reason - Maximum Vehicle Stop Time Exceeded
Autostop Disable Reason - Starter System Malfunction
Autostop Disable Reason - Stop/Start Select Switch
Autostop Disable Reason - Idle Boost Mode Active
Autostop Disable Reason - Generator Load High
Autostop Disable Reason - Low-Voltage Battery Temperature Out of Range
Autostop Disable Reason - Low-Voltage Battery State of Function Low
Edited by newdude
  • Thanks 2
  • 1 month later...
I found the issue. There’s no problem. The transmission fluid temperature isn’t hot enough. Unlike my previous truck (F150) the transmission in this truck heats up real slow. My daily commute to work is about 17 miles one way and is mostly highway.  The hottest the fluid gets on one leg of the commute is about 115-135.  I noticed when the fluid gets to about 165 is when auto start/stop begins to engage. In my case, that hardly ever happens.
  • Thanks 1
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
