Greetings. I just recently (last couple of weeks) picked up a used 2019 Silverado LT 2wd.  I’ve noticed that the auto start stop has never activated. I’m not getting any error messages and I don’t have a check engine light. I’m guessing the battery may be the issue. If the battery is from the factory, it’s probably just getting old. If the previous owner replaced the battery, maybe he didn’t replace it with an AGM battery.  I posted a couple of pics of the battery, just wondering if anybody can tell if this is the original battery or if it looks like a replacement. I’m not seeing any brand labeling on the battery, just the warning label on top.
Edited by MadMatt3883
Added text.
7 hours ago, AntonyU21 said:
It is recommended to ask a professional mechanic
I’m not spending money to fix this. If it’s an easy fix I’ll do it, otherwise I’ll leave it alone.
1 hour ago, silveradosid said:
battery has nothing to do with the auto stop, start. previous owner might have an auto start stop delete installed in the truck
Are you talking about the aftermarket cable installed behind the switch?
Have you ever checked to see if the truck has an aftermarket tune. I'm betting thats your answer
Actually, the battery has a lot to do with the auto stop/start.  If the computer detects that the battery voltage is low, it will not allow the auto stop/start to function.  This has happened on my Silverado and Traverse.  Both times I had to have the battery replaced.  Problem solved.  One way to test, which I did on the Traverse, was to connect a battery charger to the battery and let it charge overnight.  Then for the next several days the auto stop/start worked.  After that, it quit working.  After a few weeks of driving it around and it wasn't functioning, I took it to the dealer who confirmed it was the battery.
I know a lot of folks on here hate the auto stop/start, but I look at it as the canary in the coal mine.  When it stops functioning, there is an issue with the electrical system.  Could be the battery, could be the alternator, could be the current/temp sensors, etc.  Just my opinion....
It could also be like the others have posted above, the previous owner did something to disable it.
Edited by PhilB
No. What type of ODB scanner would I need for that?
My money is on the battery. I was hoping someone would be able to recognize my battery as being factory or not factory. When I have time I’m going to take it to autozone and have the battery tested.
Edit:  pulled the top cover off. Factory battery. Now I have a check engine light after disconnecting the battery lol.
Added pic.
If you've exhausted the battery and it's not the cause,  you'll need to find a tuner to look if the truck has been tuned. The dealer can also look at the tune counter and tell you. Simple obd scanner won't tell you anything.
When I get a chance I’m going to test the battery.  That battery is 4 years old now.  I’m in south Texas and down here car/truck batteries suffer from early deaths due to the heat.
Could have been a loose connection that corrected itself when you removed and reinstalled the battery cover.  Just a thought.  IIRC, there was something about the bolts that hold the connector board in the battery cover that needed tightening.
Keep us updated.
Here is the entire possibilities list of why the auto stop would disable.  I bolded a few candidates that are either somewhat obvious reasons it wouldn't work, and some not so obvious inhibiting reasons.  The auto start disable list is about identical.
I don't see where these trucks use it per the description and operation, but some of the earlier stop/start that GM used had some sort of an internal timer counter or something that the dealer can go in and reset.  Chances are if these use the same thing, you pulling the battery reset the counter.
Autostop Disable Reason - Transmission Range
Autostop Disable Reason - Passenger Compartment Heater On
Autostop Disable Reason - Driver Exited Vehicle
Autostop Disable Reason - 12V Start Counter Exceeded
Autostop Disable Reason - Vehicle Inclination
Autostop Disable Reason - Remote Vehicle Start Request
Autostop Disable Reason - Acceleration Request
Autostop Disable Reason - Transmission In Reverse
Autostop Disable Reason - Reduced Engine Power Active
Autostop Disable Reason - Ignition Switch Start
Autostop Disable Reason - TCM Request
Autostop Disable Reason - System Optimization
Autostop Disable Reason - System Voltage Low
Autostop Disable Reason - Engine Coolant Temperature Out Of Range
Autostop Disable Reason - Catalyst Test In Progress
Autostop Disable Reason - HO2S Test In Progress
Autostop Disable Reason - Misfire Test In Progress
Autostop Disable Reason - Catalyst not at Operating Temperature
Autostop Disable Reason - Intake Manifold Temperature Too High
Autostop Disable Reason - Engine Speed Test in Progress
Autostop Disable Reason - MAF sensor Test In Progress
Autostop Disable Reason - MAP Sensor Test In Progress
Autostop Disable Reason - Engine Oil Temperature Too High
Autostop Disable Reason - Engine Stop/Start Test in Progress
Autostop Disable Reason - Engine Coolant Temperature Test In Progress
Autostop Disable Reason - EVAP System Test In Progress
Autostop Disable Reason - Fuel Injector Test In Progress
Autostop Disable Reason - Fuel Pressure Test In Progress
Autostop Disable Reason - Fuel System Test In Progress
Autostop Disable Reason - Parking Maneuver Detected
Autostop Disable Reason - High Engine Rotating Torque
Autostop Disable Reason - BARO Pressure Too Low
Autostop Disable Reason - Fuel Temperature Too High
Autostop Disable Reason - System Malfunction
Autostop Disable Reason - Turbocharger Temperature Too High
Autostop Disable Reason - Hood Ajar
Autostop Disable Reason - ECM Request
Autostop Disable Reason - Run/Crank Not Active
Autostop Disable Reason - Minimum Engine Run Time Not Met
Autostop Disable Reason - Control Function Active
Autostop Disable Reason - Auxiliary Transmission Fluid Pump/Accumulator Not Available
Autostop Disable Reason - Engine Coolant Temperature Out of Range
Autostop Disable Reason - Invalid Data Received
Autostop Disable Reason - Vehicle Speed Too High
Autostop Disable Reason - Transmission Fluid Temperature Out of Range
Autostop Disable Reason - Brake Pedal Released
Autostop Disable Reason - Brake Booster Weak Vacuum
Autostop Disable Reason - Accelerator Pedal Pressed
Autostop Disable Reason - A/C Request
Autostop Disable Reason - Low-Voltage Battery Voltage Low
Autostop Disable Reason - Low-Voltage Battery State of Health Low
Autostop Disable Reason - Low-Voltage Battery State of Charge Low
Autostop Disable Reason - Low-Voltage Battery Discharge Current High
Autostop Disable Reason - Intake Manifold Weak Vacuum
Autostop Disable Reason - Engine Speed High
Autostop Disable Reason - Wheel Slip Detected
Autostop Disable Reason - Vehicle Speed Threshold Not Reached
Autostop Disable Reason - Maximum Vehicle Stop Time Exceeded
Autostop Disable Reason - Starter System Malfunction
Autostop Disable Reason - Stop/Start Select Switch
Autostop Disable Reason - Idle Boost Mode Active
Autostop Disable Reason - Generator Load High
Autostop Disable Reason - Low-Voltage Battery Temperature Out of Range
Autostop Disable Reason - Low-Voltage Battery State of Function Low
Edited by newdude
  • Thanks 2
I found the issue. There’s no problem. The transmission fluid temperature isn’t hot enough. Unlike my previous truck (F150) the transmission in this truck heats up real slow. My daily commute to work is about 17 miles one way and is mostly highway.  The hottest the fluid gets on one leg of the commute is about 115-135.  I noticed when the fluid gets to about 165 is when auto start/stop begins to engage. In my case, that hardly ever happens.
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   4 Members, 0 Anonymous, 964 Guests (See full list)
    • It seems fine because it pulls everything out of a hot engine. I’m not going to worry about a thimble full with 5K oil changes with synthetic oil. Every other oil change is at Honda they pull the plug. I watch them through the process. It turns out going to Honda what amounts to their normal oil change intervals.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
