I have a 22 Custom and it’s almost time for new tires. I’m not a huge fan of my custom wheels and have been looking to upgrade to a higher level OEM wheel set. Has anyone driven these trucks with both 17” and 20” wheels. Is there a noticeable improvement in off road dampening with more sidewall or does it not matter with the E rated tires?
thanks
Ride would be close to the same if not the same.
What would change big time is the speedo.  The stock 20s LT275/65R20 is a 34.1" tire, the stock 17s are LT245/75R17 or LT265/70R17 which are a 31.6" tire.  Sidewall height is within .3" of each other.  7" for the 20s, 7.3" on the 17s.
Thanks for the info. I did not check the tire heights and assumed the 17'' tire would have the same over all height with more sidewall.
The stock 18" tires which came on my AT4 will have the most sidewall of these 3 tire sizes as it is 275/70 R18. I had to select many of my options separately to avoid the 20" tires which came with the preferred package as I did not want the 20" tires.
The stock 18" tire has a sidewall height of 7.6" instead of 7.3" and 7" for the other 2 tire sizes mentioned. So, for me it was a big difference between the 18" and the 20" tires (about 10% difference). For you it would be a .3" difference on the sidewall.
But the 18" does have a diameter of 33.2", which is 1.6" larger than your current tire. However, your speedometer can be recalibrated by the dealer for different size tires. They do the same thing at the factory when the vehicle is assembled.
Another option is to keep your current wheels and get tires with a larger aspect ratio. Then have the speedometer recalibrated for the new tire diameter. This method would allow you to get the most sidewall before having rubbing issues on the fenders/linings. Some dealers will do it. There are other ways as well. But the speedometer error is only 3 mph at 60 mph for changing the tire diameter by about 1.5". So there's no reason why you couldn't drive like that if you wanted to.
Just be aware that more sidewall means less handling in corners.
Edited by Dr1ft3r
Yeah I have the stock 18” and would never personally want 20” wheels on a pickup. I prefer to look and road feel of more sidewall on a truck.
now for a sports car I prefer the low profile look.
Edited by Pryme
Don't like the look or the price of 20's.
OP has a Custom which comes with 20s so the 18s are smaller by 0.9".  275/65R20 is 34.1", 275/70R18 is 33.2".
Dealer can only calibrate to tire sizes that are optional by trim.  So on an LT, they come standard with 17s, 18 and 20 are optional.  If the truck was built with 17s and could have been configured when ordered with 18s or 20s, GM will be able to issue a calibration.  All Customs come with 20s and that's the only wheel/tire combo available so they won't offer a calibration for any other factory size because they only come with 20s.
Edited by newdude
Oh, my mistake. I thought he had the 17s. 18s still have more sidewall than the 20s (.6" more sidewall).
Lots of people run much larger tires as well as lifting their trucks to accommodate those larger tires. There are aftermarket shops which can recalibrate the speedometer. It's not very expensive at all, usually around $100.
Edited by Dr1ft3r
Cant stand anything less than 18in on a truck, and to me 20s look the best by filling th wheel well.  my 2022 AT4 had stock 18s and bought and replaced them with stock 20s,  didnt notice the difference on the speedo, checked with GPS.  Sidewalls on the stock 18s were taller, so the overall difference was minimal
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
