I live in Bryan, Texas.
I'm retired US Air Force (1 September 1994), retired from civilian job with Reynolds & Reynolds (Jan 2022).
Over the years, I've owned numerous cars and trucks. The trucks:
1987 Ford Ranger 4X4, standard cab and 7ft bed, grey
1995 Chevy 1500 extended cab, standard bed, light grey
2009 GMC Canyon extended cab, white
2011 Ford "heavy half-ton", crew cab, standard bed, grey
2019 GMC Sierra 1500 SLT, crew cab, short bed, grey
2022 Chevy 2500HD LT, crew cab, standard bed, white
Our 52nd wedding anniversary is 6 Aug this year.  Three kids, 8 grand-kids, 6 great-grandkiddos.
I want to remove the bench seat and install bucket seats and console like our 2019 Sierra had, install an inverter and connect the two 120VAC outlets like our Sierra had. Oh, and mount a rear camera (not back-up only) on the back of the cab in the brake light cover.
We're planning on getting a 5th wheel when our house sells and visit kids and their kids.
Edited by GaryR
That 2011 Ferd, was that a 7700?
Have you been to that armor museum in Bryan that lets you ride around in their tanks and half-tracks?
  • 1 month later...
