Long story short, I traded my 2020 trailboss for this truck and I’m pretty happy minus a few luxury items missing. I’ve noticed that slow speeds turning or where the truck bed shifts, I hear a pop and I don’t like it. I’ve read maybe just the leafs doing it and a piece of rubber will fix it? Also, I notice with no music on, truck running, I hear a hissing sound from the steering wheel…hard to explain but it changes when I turn the wheel and sounds like a hydraulic line!? Normal?? Any insight because I know dang well what the stealership will say and I don’t want to go through it all if it’s actually normal. Thanks
Steering is normal and even more normal if it has the digital assist steering.
Rear noise its likely the leaf pack.  "20-NA-022 Squeak, Grind or Clunking Noise from Rear Leaf Springs" and "21-NA-138 Squeak, Grind or Clunking Noise from Rear Leaf Springs" are the two bulletins on leaf pack noise.
Are those bulletins for 2020-2021 is that what the 20 and 21 stands for? What about 22+
Same with the hissing on my 2022 lt…..only hear it with no music on in park or at idle and reacts to steering wheel moving or once you start moving…..annoying but have had no issues with it other then being annoying
Well glad to hear it’s “normal” now to decide if I want to try and make the leaf noise go away with rubber strips or leave alone. I read some guys had the noise go away after 1000 miles or so and I’m only at 88 so I got time lo. The steering is so odd, mine is a Custom trim so I don’t think I have that digital assist but it’s definitely noticeable
The creaking in the rear goes away if the underside is drenched. Mine creaks when dry. 5100mi
The hiss noise you hear is the power steering system. Its a hydraulic system and the noises are perfectly normal.  You hear a howl noise at idle with no movement on the steering wheel. Noise changes when moving the steering wheel.  Totally normal.  6.6 gas comes with hydraulic power steering and hydraulic brakes.
Covers multiple years yes.
These are noisy trucks, every single T1 2500 I've had made that steering noise.....I am not concerned unless the basic function is affected.....but yeah my 1500s were much quieter vehicles ......
I have digital steering now and it sounds sane as my LT's DID AT HARD LOCK on steering
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 395 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
