13 hours ago, UWSkier said:
We almost bought the 2800BH (assume that's what you have) to give our dog a place to sleep and to get the bunk storage! :)
Yes we have the 2800BH.  We love it and will have it for years, it's just a tad too big for us but it's hard to complain about having lots of room!
Jet, at first glance my initial thought was "that trailer is nothing behind that truck" And that's exactly the point of HD's. Whenever I've had anything behind my HD, I knew I was in charge by way of overwhelming force. Can't put a price on that kind of confidence.
 We had a pretty decent size trailer boat (6000#) I pulled with my 3500 Silverado some 20 years ago. Went all over on week long trips to Lake Erie and the TVA lakes in Tn/Ky for many years with friends. And more to your point, made friends that I'm still good friends with today even though we've scattered all over the states. It's funny how most of them have transitioned to campers. One guy even sold his house when he retired, bought a class A coach and never lets grass grow under his tires.
 Interestingly, I was talking with some friends the other day and it's when I realized, "I've always been in a truck family. All my best memories were fishing and hunting with my dad, my granddad, uncles and whenever we talk about old times that's how we dated the period, buy what truck, color, who had where, someone always had a memory of the role a certain truck made at this or that moment of life" .... There's a lot to American life and trucks.
 i sent a photo to a buddy of mine in the UK, he said "that's a beast but dude, you could barely drive that here our roads are so small and you'd never find a place to park it" .... I thought, that's kind of sad, you'll never know what your missing.
I think that's one of the best comments I've read in a long time.  God love you all....Be well and thank you so much for that reply.  Life is short, enjoy it all you can because life is all about making memories, not just for you, but for all family and friends around.  I love this!!
Love seeing all of you with GD trailers. We love ours! Coming up on 2 years of owning it. Plan on keeping ours till the kids are teenagers.
I really want a 5th wheel Reflection... but can't justify it as we need the truck bed for my 120lb dog and meat smoker.
  • Like 3
We love ours too.  The only reason I would get a 5th wheel is just because I've never owned one before.  But in all honesty, I can't find one that surpasses our GD 2800BH....I've watched a ton of videos on youtube...I just love our layout and the room we have.  One of my favorite youtube guy that does reviews is Josh the RV nerd..That dude is 100% honest and spot on with RV reviews.
Edited by Jettech1
I met Josh at an RV show in Novi MI last fall. He was doing seminars in the afternoon and I got a picture with him afterwards. He is much more subdued in person. He started out at their store in Coldwater MI.
I'm so jealous!!
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
