Hello All.
Just bought a 2024 GMC Sierra 2500 HD Denali.  Setting up the trailer, it wanted me to drive forward to calibrate the trailer length indicator and jack knife alert and a third one.  Drove around the block a few times. System says calibrating but no progress bar or any other indicator. Gave up for the day.
I do not have a camera on the trailer, is this the problem?
Did you ever get this figured out? I just hooked my trailer up for the first time and cannot get the jackknife alert or the trailer length indicator to calibrate.
Not yet. Bringing it to dealer end of month. I will post if it gets sorted. A few other users on Facebook also having the same issue. I have also added the camera now still same problem.
I don't think you need to calibrate the trailer length or Jack knife.  After inputting dimensions in trailer profile, if you drive around with trailer.  If you put your turn signal on, you should get the turn signal view with a red area.  This red area is the red carpet view.  If so, the feature is working properly.  I'm not sure on jack knife, I have only demo'd with transparent.  I would put in hitch view and see if an icon is in upper left with jackknife.
If you need help with transparent, let me know.  I have setup about a hundred trailers and know the tricks.  Follow the camera install instructions and drive straight under 30 mph to calibrate.
#iworkforGM
I havent towed with my 2024 yet but I know that my 2021 would take a few miles before it operated properly. Its a less complex system than the 2024 but it still took the truck a little while before it calibrated for the fact that the trailer was behind it.
Thanks. The turn signal view works without the red carpet, it says drive to calibrate. None of the trailering featurs work. I have even deleted the trailer checked measurements and set up again. You tried to help me with the camera install in another post. Emailed GM and It is going into the dealer at end of the month. From other groups apparently the blue hourglass in top left in the below picture is a problem.20230626_144308.thumb.jpg.0f37cb904b1bd5c9978950930061b094.jpg
#iworkforGM
Hi there, I just bought a 2024 Silverado 2500 and don't get the "red carpet" view. Does it only work if it senses a vehicle in that area? Searching around the internet for more info It seems that the trailer length needs to be set for this. I cannot get it set up using my 22' travel trailer. Hoping you might have more answers, info on this topic is slim.
I tried everything I can think of, entered all the data it asked for and I'm in the same boat.  I DO NOT have the trailer camera (yet - supposed to show up tomorrow).
Make sure you height is no more than 118".
The height doesn't affect anything except calibration.
My height is 157" and it works fine on mine. But mine is a 2023, if that matters.
Edited by Dr1ft3r
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
    • I think the ship has sailed on the fuel injection type - everything is getting direct now.  Does it help with mpg?  Not really and nobody buying a HD truck really cares anyway.  But that is what it is at this point.  Piston rings is something they may well adjust over time to get them right.
