Had our family vacation in which we just arrived home at 1am this morning in a rental. From Anaheim, CA (Disneyland) to Lubbock, TX (home) it gave out in Tucson, AZ. Slipping so bad rpms jumping to 3K and barely moving, Trans Temp 198. Dropped it off at Watson Cheverolet there in Tucson. Service guy called me on the road and no codes were pulling up, but his transmission tech says something is definitely wrong internally.
Looking at a little over $7K for a GM rebuilt transmission with 3 year/100K mile warranty which includes parts and labor.😬😮‍💨 The most expensive vacation we ever had.
Wifes ride is 2016 Yukon SLT, 2wd, 5.3L w/ 120K miles. Oil changes religiously, trans flushed about 40K miles ago, I just did brake pads replacement, A/C condenser replacement. Think the 110-114* was just too much for it had we counted about 30 vehicles on side of road (most blown tires, others engine/transmission problems likely).
Parents Acadia engine went out, had it replace with rebuilt for $10K, my TrailBoss trans cooler line leaked(replaced under warranty), Passenger lifter failure (replaced under warranty), and now has a shuddering in the transmission😔, and now wife's Yukon transmission failure...
Thoughts, suggestions? Wife wanting to switch brands and I'm on the fence.
Living in south Texas we live with 100 plus temperature at least two months of the year. Seems like you’re doing proper maintenance. Probably people with tire problems are running them too long. All my vehicles have at least 130K miles except one toy. Don’t have  any temperature related problems. Could be the brand or a run of bad luck. You know what they say bad luck runs in threes. My GM has the most miles of the bunch, no problems.
They do come in threes, that's for sure!
Once it's ready, I'll have to fly there, pick it up and head on back. I do keeps files/folders on all my rides for service done or parts bought for them. I'll just try to keep her going until we decide to sell/trade-in.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
