the should have instructions on their site for removing the overhead panel. You will need plastic trim removal tool to pop off the two curved plastic pieces to access t5 star head screws. Then use the trim tool to pop it loose from the roof.
Having done their P&P harnesses on a few vehicles, the hardest part is disconnecting the OEM harness connections, especially if you have bigger hands. Don't be afraid to use channel lock pliers if you need help depressing the connection release, just be careful.
Edited by jaxcam02
Thank you Dan
, I didnt know about the star head screws.
Ither is a utube video but it is totally different than your directions.
I real,ly appreiate your help and knowledge, thank you very nuch
John
Thank you again for your helpful directions
i got the two moldings off and the two star head upper screws out   The upper portion is free but the bottom portion above the on star button will not release. Is there a release clip somewhere that I am missing?
thanks
john
thanks
john
There are 4 screws, the 2 down by the onstar buttons are recessed.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
