Believe its 10sp only. I have a whine also while driving or in park. Not sure where it's coming from but they didnt seem to concerned. If you take yours in and they fix it, let me know. Maybe I'll hit the back up and ask again. Mine has sounded like this since day one and it never gets louder or lessens the more it heats up. Its all a constant.
1 hour ago, Pryme said:
Oh man I remember that sound from back in my car audio days. That would drive me up a wall. I don’t think this sound has to do with the 6spd. I’ve never heard it.  Must be 10spd only?
My 2021 with the 6L90 does not make any noticeable noise I associate with the transmission. I’m only at 15k miles, though.
I’ve got 2k on ya. Two low mileage queens haha
On 2/18/2026 at 10:19 AM, Byrds8 said:
https://static.nhtsa.gov/odi/tsbs/2024/MC-11012007-0001.pdf
It has a few items on this list but about youre looking for the below portion.
Reaction Gearset Whine (Gearset One)
With variation in gear tooth finish and positional control, some customers may experience whine from the reaction
planetary gearset during light to moderate driving conditions.
Most common conditions to hear whine from the reaction gearset is in 4th and 5th gear (20-35 MPH) (32-56 KPH).
Reaction gearset is active in gears 3-6 and 8-10 so depending on severity it may be possible to hear in gears other
than 4/5.
Frequency of whine will change as transmission shifts gears due to component rotation speeds being changed.
Utilizing manual tap to shift through gears is a good way to verify what gears whine in present in.
Note: Whine from the reaction gearset should not be present in 7th gear due to the 1:1 ratio and gears being locked.
If whine is present in 7th gear, issue likely lives with some other component.
I’m not sure if I’m reading this right but the TSB seems to say that the trans shouldn’t make a noise in park? I think every 10L1000 I’ve seen (including mine) has a slight whine in park so I figured it was normal, but this TSB isn’t very clear.
I would think the reaction gearset noise (which is what I believe the noise I'm referring to is) shouldn't be heard in park. Only in the gears mentioned in the TSB.
Beats me all the way around. Mine has a whine in park (assume it's the transmission) and has the planetary gear whine around 3rd and 4th up to about 38mph. It shifts fine and the dealership doesnt seem to worried about it so might as well ride it as is. I have wondered if it was just low on fluid because some have said theirs was but haven't bothered to check.
The noise that can be heard in various gears is a separate noise than the one I can hear in park or slightly rolling through the neighborhood. The one for in park mentions it gets worse as it heats up. Mine is a constant. Never gets any less or more.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
