Brand new 2023 GMC Yukon XL SLT.  Hit road debris and ended up with a hole in the drivers side stationary Assist Step.  Can I replace the Step myself?  Does it involve more than removing and replacing several bolts?
Looking at the exploded diagrams on the parts sites, they seem like they are the same general design as most... Brackets bolt under the cab, step rests on the brackets, additional bolts through the brackets into the steps. I would expect replacement to be pretty straight-forward, but price might not be so fun.
Thanx.  I can find a Step about 30% less than the dealers price.  I agree, looks relatively straight-forward.  Did you notice in the diagram the brackets, the step, and what looked like along strip of metal.  Would that be the plastic strip along the outside of the step?
Got it, seen several like this looking for the best price.  GMC going into the body shop tomorrow for hole in the door during the same road debris incident.  TY.
Here’s our sad story.  Left Maine in late Oct in our 2016 GMC Yukon XL Denali.  Made it to PA for the night.  Next morning, crossed into MD and the Yukon’s engine went bad, was able to get to a local dealer, after 2 hours & $500, they said the problem was inside the engine and might cost up to $5000 and might take several days if they didn’t have the necessary parts.  In Sept we had just spent $3500 on the lifters being replaced.  The two or us and the dog, no rental cars available until some time in Nov… They had an SLT, Denali and a Denali Premier on the lot.  We bought the SLT with payments for 84 months and we were on our way to a hotel that evening.  That’s #1.  Made it safely to our kids place in SC the next day.  After three days we left for FL.  About an hour out we hit road debris on the left front (GMC 3 days old).  Scraped the left front bumper/will be buffed out, and put a hole in the Assist Step and drivers door (going to dealer for door repair tomorrow).  That’s #2.  Arrived in FL and the A/C in the house went out.  That’s #3.  Auto insurance in FL is high.  Don’t need a $2200 claim on my record and a policy increase next year.  The Assist Step will have to wait.  Three hits in a row, let’s hope that’s it for a while.  Happy & Safe Hollidays to you and yours.
Sucks when life gangs up on you like that... Not sure what other years would be interchangeable, but maybe you might find one from a salvage yard...
Be well, be safe.
Watch out for shipping.  Especially if you are on GMPartsDirect or something like that.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
