I traded my 2011 Tahoe in last year for a 2022 Sierra 1500 LTD X-31. We were able to flat tow the Tahoe behind our motorhome without really doing anything to the vehicle itself, which we did for multiple trips and thousands of miles. Bought the Sierra primarily so we could put the golf cart in the bed on occasion.
My question is has anyone set a new Sierra up to flat tow?
The base plate is the easy part. Not sure about the rear light wiring. I had a diode setup with the Tahoe and it worked well. I just don't know if the Sierra lights are as simple as the Tahoe was. Next, GM says you have to disconnect the negative side of the battery. I figured I could just get a marine or some other type of switch to disconnect. The positive side terminal has a crazy connection, but the negative side has a weird terminal connection as well. Once the car power is disconnected I'll still have to have a dedicated 12v running from the battery to a cigarette lighter style connector in the cab to power the aux. brake.
Lastly, (I think) I've only tried putting the transfer case into neutral once. My 03 Silverado, and the Tahoe were very simple. This thing involves the emergency brake and a sequence of button presses on the 4WD switching, dancing on one foot, tuning around, and an apparent sacrifice to the gods to get the Transfer case switched. Then a similar dance to get it back into gear when you're done. All in sequence as it needs to be done before disconnecting the battery.
Oh yeah, I guess you have to use the little emergency key to lock and unlock the door since there's no power??
Thanks to anyone who has info and has done it. I'm hoping it's not as complicated as it seems to be.
Edited by Stratman50th
With the X31 package, getting the transfer case into neutral is easy.  With the engine on, put the transmission in neutral with the parking brake on, then press the 2-Up button five times.  To get it out of neutral is a similar process, but press the 2Up button once.
Personally, I would probably disconnect the drive shaft and prop shaft since they are super easy to do.
Edited by Gangly
I would pick another vehicle to tow unless the truck is needed as a truck. Hauling, towing etc. Did you consider the weight?
Thanks! Going to practice the procedure a few times.
Weight? It is my daily driver, but like I said we wanted to be able to put our golf cart in the bed when we want.
All that info is in your owners manual as it tells you how to flat tow or dinghy towing.
Paper manual in glove box is weak. At least it is with my '23. Go online to mychevrolet and view the complete manual as the paper one only glosses over features and procedures.
Some of the things I mentioned I haven't really found addressed in other places which is why I asked. Taillights for instance. The new vehicles seem to have more than their fair share of integrated sensors and wiring. I don't want to brick this electronic wonder just by installing the diodes in the taillights for running and brake lights which are controlled by the coach when plugged in. Gears, parking brake, transfer case are all electronic, or have some electronic controls and/or components. I've never had to disconnect the battery before to tow. Even the base plate which is seemingly a simple bolt on that goes where the tow hooks are now can be dangerously close to the in-bumper sensors for the park assist. So the question is more than just about the actual "towing". Nothing in the manual addresses the actual setup, wiring, auxiliary brake, etc. I've towed several vehicles over the years and this one is the most sophisticated electronically. Oh yeah, I have gone through both the paper manual as well as on line info. Joining and posting here is just another step along the way of getting this vehicle set up to tow.
  • 4 months later...
flat towing my 2022 GMC Sierra following the directions in the manual and the Roadmaster tow bar installers instructions I get a hot burn smell after i disconnect and drive the vehicle. Fluids seem fine. Goes away after a short drive. any thoughts?
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
