2024 GMC Sierra 1500SLT crew cab x31 package 5.3L
Where to began.
1. Took delivery of truck with 3 miles on it, salesman went through and help setup truck took out of demo mode. Setup onstar, wifi, and connected phones to the system and saved everything. Wife and I go eat on the way home. All settings cleared and went back to demo mode. Wife took truck back to deal next day the did a reset and programmed again. Its working yea.
2. Took a trip with truck less then 300 miles on it with the auto off turn off and truck dies while coming up to intersection. oh goodie to start the truck you must put in park and press brake for it to start, putting in neutral doesn't start. This has happened 4 times and no codes have been detected at dealer so they can't duplicate it.
3. Infotainment system is looking up on maps and no GPS this is a weekly issues dealer can't duplicate that ether. It's done it enough that we have sent the videos to dealer to show them.
4 OnStar issues, Drivers side microphone went bad less the 1k miles on truck.
5. Drivers information panel changes displays on its own when starting truck and its worse sense I just got the truck back out from dealer.
6. Phone charge cradle sucks. You have to stand on your head stick your tongue and put your arm out the window to pick up phone and that's without a case on phone. Once you get it to connect and you drive off it drops charging. They put their little test box on it and says they can't duplicate the problem. Well we all know there test equipment was designed to work on the auto even yours don't.
7. It has a relay clicking sound in the dash between the defrost vents and infotainment display. Dealer can't hear it ether and duplicate.
I told them drive for a few days. Have service manager take it home daily so they could see and hear the issues. They had it for a week and he drove it one day cause I tracked the truck daily with the GM app.
OnStar even put in service notes truck has issues.
On the phone charging issue there is a known issue with iPhones running IOS 17.1 and later not charging in GM vehicles. (17.1.1 and 17.1.2 did not solve the issue).  Hopefully there will be a fix in 17.2.
Wow that is a lot of headaches. I picked up my 23' in October just ticked over 2600 miles and haven't had any headaches. The only annoyance I find is that sometimes plugging in an iPhone to use Car-Play/Charge doesn't recognize it, so you have to unplug and replug and on rare occasions restart the car.
The wireless car play is a hit or a miss so I stick with hardwiring it, and have no problems doing so.
What if you pull the battery terminals +/- and wait a few minutes and reseat them. I wonder if that would fix some of those weird headaches you're having for the infotainment.
The dealer has done all of that your speaking of ARedSierra. Today before she took it back to dealer for the 5th time with only her driving it sense last night the set memory placement moved on its own. Today the dealer has reset the system and pulled information  to send off to GM tech support for the second time.
Sounds like a nasty batch of gremlins.  You know you're not suppose to feed them after midnight, right?
  • Haha 1
Well 2 new ones have come up now.
1. When remote started the temp controls have stopped working and yes the controls always are left in auto.
2. Today wife starts truck and both drives display and infotainment screen go black while driving off, shorting after hitting a bump in parking lot both displays come on but no sound from the radio. Change the channel sound comes on.
I think we are at a point were too much runs through the infotainment systems and like any home pc, you get what your pay for! And my bet is gm uses the cheapest of cheap hardware components to run these setups and with in house crap made software to match with crap cheaply made hardware it is not shocking to see all these issues!
It's not just fullsizes, i have seen these same common complaints with the Colorado and Canyon lines.
Edited by BIGDOGx
The truck controls the temp by the outside temp probe located under the passenger outside mirror. It doesn't matter what state the controls are in when the truck is turned off. I turn mine off every time I leave the truck but, when I get in from remote start the defrost is running on low (now that it's cold) before I push the start button. There should be no lights lit on the dash when running during remote started either.
Technology has advanced well beyond the point where industry can/will keep up. All the way from design to implementation to repair. Unfortunately its not going to change because the 2027 HD's are rumored to have a new architecture (the one that wont have Android auto or Apple carplay but will have subscription only services)
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
