I just ordered the GM version.
Used my points and a 20% off discount got it for $140. Anyone else have this?
I needed something to keep my daily cash pile in and this is better than nothing.
I have the Lock'er Down EXxtreme console safe with their metal cased Electronic lock. It was pricey.
i have the folding arm rest in the front that allows for another seat. I found one that mounts underneath it. Mounts a pistol no problem.
Locker Down or the Console Vault look very similar.  Locker Down has electronic locks if that is what you like, but the Console Vault is a little less expensive.  I would like to see something a little smaller as I don’t have that much I want to lock up and using either of these would interfere with my after market tray.
My tray sill fits just fine and the light is not blocked either.
Lock er down has non electronic key pads as well as I ordered the mechanincal one but they mistakenly sent the electronic model, which is indeed more expensive.
I have a tray from Amazon.
If you do, I might be interested in buying one from you.  Or at least pay for the file so I can print it here.  I just installed the Lock'er Down in my '23 as well.
I bought a center tray from Amazon and notched it for the electronic lock on my lock'er down safe.
Yea, that may be the easy route.  We will see once it gets here.
Which tray did you go with? I installed the ConsoleVault with the elite lock, the oem tray no longer fits well.
This is the tray I bought from Amazon:
Center Console Organizer Tray for 2019 2020 Chevy Silverado 1500 / GM Sierra 1500 Accessories Replaces 84106530
  • 5 months later...
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
