Anybody received any OTA vehicle software updates on a 2024 Silverado or Sierra 1500. I have received some google play store and apps updates, but nothing as far as vehicle updates.
You might want to NOT go looking for updates or allowing them to be installed...
There are a number of folks that experienced issues with OTA updates essentially "bricking" their trucks due to either corruption or the installation of updates that are not actually for your truck. I experienced a litany of issues with my 2024 that were (finally) traced down to being corruption in the software of the communication gateway control module. During the time I was experiencing issues, I got pretty much every warning light and message you could imagine, including being told "Service Steering Column Lock" which my truck doesn't even have.
Since getting my truck back, I have very purposefully turned off every option I could find related to downloading and installing OTA updates. With my Camaro, I have been happy to let a few updates that came along get installed as they have all gone smoothly AND they corrected some oddities. With the truck, however, there's no way I'm allowing this to occur again. For reference, I did have an OTA update that was installed maybe sometime in November (ish) and the problems started a few weeks after that.
GM has been having many many problems with their OTAs. Including disabling your truck. You mav not want to go looking for trouble. Just search this forum for examples of people having problems after allowing OTAs.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
