I've been interested in getting a console safe for my '23 Silverado LTZ. I was looking at review videos and saw this company. Does anyone here have one of these or know anything about them? Price is comparable to the GM safe but looks more secure.
Chevy Silverado 1500 and GMC Sierra 1500 Console Gun Safes – WASAI® (wasaisafe.com)
Honestly it just looks like a different lock, the GM one is pretty stout IMO. the lock is a little bit of a pain now and then but you also dont have to worry about changing a battery out. hope that helps a little.
I just picked up the GM version.
Used my points and 20% off and got it for $140.
Works good for what I need.
Thanks for the replies. My concern is the lock on the GM safe. Maybe if I saw one it would help. I saw a video comparing what was supposed to be a GM safe and I think Lockerdown and the GM safe didn't look good in the comparison.
definitely not pretty and to be honest it is a cheap tumbler lock but to be honest if someone want in to any of them all it would take is a decent sized screwdriver to pry the lid open. its more of a deterrent than prevention.
IMO whether it be your house, your car, or just your console safe, if they want in bad enough they will.
  • 1 year later...
On 2/13/2025 at 4:33 AM, Dylasnemo said:
I’ve been looking into console safes myself for my truck, too! I’ve seen a few brands pop up in reviews, and honestly, they all seem to have their pros and cons. I ended up going with a safe for my truck after a few bad experiences—like the time I left my laptop in the backseat and came back to find someone had tried to break in. It was a rude awakening! But since installing it, I’ve felt a lot better about leaving things in the truck.
What brand of safe did you install and why did you pick that brand?
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
