I'm trying to get my first truck and I found a 2003 Chevy 1500HD with the 6.0 Vortec and 4L80E. The truck has 168k miles and they are asking 9k, it seems to be in decent shape, so what kind of problems and reliability would be able to I expect from it? I've heard horror stories about the 4l60e so I'm trying to stay away from those.
Edited by Alex Boddy
The 6.0 and 4L80e are fairly bullet proof combo's. The 6.0's can have oil leaks and broken exhaust manifold bolts are super common, so make sure all the bolts are there. Usually the heads break off and cause an exhaust leak.
Just think of a 1500HD as a 2500 truck, it's all heavy duty parts and heavy duty pricing on stuff. Parts are costs a little more and tires cost a lot more because they are LT rated. Also the 1500HD's get terrible fuel mileage. You will likely avg only 10-13mpg at most. It might get 15mpg on the freeway if it doesn't have 4.10 gears and you drive it nice.
$9k seems like a lot for a 20 year old truck. i paid $2600 for my 04 2500 hd 2 years ago with about the same mileage. Other than repairing the gauges in the instrument panel I have had 0 problems so far but I am getting some vibration from the rear diff now so time to do the bearings more than likely. My rocker panels are getting soft on the back side and frame rot can be a problem if you live where they salt the roads so pay a local garage to put it up on the lift and do a pre-purchase inspection. Welcome to the Forum!
A real clean body GMT-800 in Minnesota can cost a few extra bucks for sure. I wouldn't be too bent out of shape paying a little more for one.
I say that because yes I could fly south to buy a rust free truck that might be cheaper than one bought in my home state but it does cost money to do that. The cost of the flight, food, gas and stuff to get back can eat at the savings on the truck.
    • The no sound problem is the audio amplifier. The audio amp has a heatsoak issue in some circuitry which causes it to miss the wakeup handhake. If it doesn't respond within a certain time parameter, then you get no sound. I brought it in and had the software update, but after further testing the tech made the call for a new audio amplifer. The software update I belive gives more time for the amp to respond, but if the amp is defective then you can still get no audio at times. After the update it went 12 days before no sound. After doing some research, apparently the fix is a new (updated) audio amplifer, the circuitry internally has been improved to better deal with heat. I had to wait 2 1/2 weeks because at the time, it was on backorder with no eta. Well the amp came in earlier this week. I had the amp and programming work done today. After picking it up I stopped at a few places, and whenever I started my truck, the audio was on instantly, so whatever they did it appears to work because it's never had sound that quickly......Hope this helps
    • Make sure the latch mechanism is properly greased. Look at the catch for fresh marks/scratches. And see if it has moved a little, too.
    • I have the 18" black mutilspoke wheels that came with my truck. I like them as they are very subdued and look good with the 295/70's    I am sure that the next set of wheels I get will be some after market all black wheels. Or maybe some AT4X wheels.
    • Interesting question which you partly answered in the word 'potentially'. I think that is going to be a 'point of reference' inquiry. What are the touchstones?    This will sound petty but it is the main source of end fighting in threads on this topic. Define a motors "Life". Think about the various arguments that have been entertained on these pages in that very argument.    I can only speak from my viewpoint. Engine "Life" in my world is defined by power cylinder integrity. For the majority of engines it is the bore/ring interface that quits first. Loss of seal. Oil consumption and loss of power. Most Pro motor builders would agree and there is a good deal of information on using "Leak Down" as a primary indicator of bore integrity. At home a compression test is more the thing. If we can agree on that then I think CC Jensen has done its homework and I'd find it valid.    Now by my own definition, Dizzy, wife's Ecotec 2.4 I-4 has been dead since about 80K miles. And yet we have logged over 200K miles more on it. "Life" and "Usefulness" are therefore independent.      I know a mature fella right now who has just hit 300K on a Mitsubishi 3A92 NA MPFI motor and has done compression test every 100K. It was 205 psi after break in and is now about 195 and still even. He uses shelf oil but good filters and adheres to a 3K mile OCI. He even do UOA's on each of them for the first 50K.      I also know a fleet mechanic with that same motor that gets 300 to 500 K out of them but the are oil using, wristpin sloppy, skirt slapping motors. He ran one with a piston pin so loose the piston was bouncing off the cylinder head for about 20K miles before he called TOD. Both of them claim success.
    • Shouldn't the fault be saved and able to be pulled with a reader? Otherwise, maybe start taking pictures of it which will have a date and time stamp, so you can build your case.
