I had the Kelderman system put on my 22 truck, some of the best money I've spent on this truck.
I have the Ready Air set up with the onboard compressor, works great.
Can you provide a review on these? I'm looking at getting a set and would like some feedback on these. Which compressor did you go with?
I went with their HD compressor.  Works fast, can save numerous different vehicle towing profiles to return to your preset psi settings.  I have one saved for just the truck camper, truck camper and trailer loaded with toys, unloaded, etc. So far I'm impressed.  Can give more feedback at the end of the summer, plan to put them through hell.
Looks nice! My buddy is looking to get Ready air as well. He's preparing for a week-long trip and the new BFG's, kmc wheels, and brake pads are on the way.
I have the firestone, separate fill valves reduce body roll,  i'm not sure You can avoid one airbag transfering air to the other  with an onboard compressor..
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
