I installed this oil catch can only 3,474 miles ago. It was installed 1,213 miles after the last oil change.  I had not checked it until today when I did an oil change, and I was surprised to find that it was full, up to the treads!  I can't imagine it was very effective if it was sucking in its own excrement.  There was only a very small amount of "milkshake" at the very bottom of the catch can that was visible once I drained the contents.  I use Kirkland Signature (Warren Distribution) 0w20, and this is a 2019 model year 5.3 AFM engine with nearly 69,000 miles.  Thoughts?
Edited by BlaineBug
There are many vehicles without catch cans that do fine. I prefer to have one. So many factors, temp, humidity, oil used engine condition etc.
I just prefer catching whatever it will instead of it going into the engine.
Check it frequently if you live in "cold" climates.  My Elite will be full in 4-500 miles of cold weather driving.
4 hours ago, BlaineBug said:
Have never seen it low at all.
I asked as you mentioned:
So, if it isn't moisture (milkshake) and it isn't oil (you're not using any) what do you think that considerable amount in a very short time is?
It has to be oil in that case, of course, but still unusual.
Yes, living in Chicagoland currently, although this winter was mild, with only that brief stretch with a -10 chill around January 10th.  In progress of moving far, far south to the opposite extreme.
Funny, I noted JLT I believe it was recommended checking their separator/catch can every 10,000 miles!  Of course they have a larger reservoir but not 3x+ as large!
I just checked my catch can way early this time, only 428 miles post-oil change, and was surprised to find a bit of what appeared to be fresh engine oil (looked just about the same as the oil that went in, no water.)  I did not measure it out, perhaps next time when I'm expecting it.  For the last oil change I used 7 quarts 0W20 Kirkland Signature (Warren Distribution) and 1 quart Marvel Mystery Oil.
Edited by BlaineBug
Seems to be working fine IMHO.
Hope so, seemed to be more oil than what I would have expected for so little miles, also no frigid temperatures or short driving trips either.
In temps below 45-50*f or so is when I start seeing the milkshakes in my Elite CC.  It doesn't need to be "frigid"!!!
In straight highway driving in those temps or lower;  my CC will be full in 4-500 miles.  In suburbia driving in those temps;  I'll check my CC every 3-4 days...............especially if a lot of short trips where truck is shut off without coming up to full operating temps.
Milkshakes yes - but straight, clean oil??
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
    • If they had nuclear material for "11 nukes" we'd have seized it.    Our military has been rendered either too weak/dumb to seize it, or they don't have it. Your pick,K-nut. Because right now we're fighting over who gets to toll oil tankers in the strait.    I hope you're man enough to admit you've been taken for a ride when it's finished.
    • I hope you’re man enough to admit that you were wrong when it’s finished.
    • And you're obviously full of it too.  Apparently anything he does is perfect to you.  Don't you think this whole ordeal would have been better if he had maybe thought it all through first before bombing Iran at the request of his bffs in Israel, Saudi Arabia, and Qatar?  They are the ones that had the biggest issue with Iran.  Thus they have been pouring the platitudes and giving gifts/bribes to him.  Had he thought about the consequences of what would happen to the Strait before starting anything, we wouldn't have this issue.  Now he is stuck with no way out of this mess.  But you have your head stuck way deep in his rabbit hole to see anything else.  So no, I don't have TDS.  I see what he is.  The derangement is yours from no oxygen in the rabbit hole.
    • Bringing of the fact that every President has said the same thing. They can’t have nukes. I guess you missed that before epic fury they said they had enough product for 11 nukes and weren’t giving it up. That not political or polarizing. The opposition of that is and giving aid to the enemy. The mandate is decades old through many administrations. The difference is TDS.
