Anyone here in replace your recovery hooks? Mine are getting a little corrosion/rust on the bottom, so thought I would get ahead of it now and swap them out (not paint) and was looking at the OEM replacements as well as aftermarket.  Im seeing a ton of aftermarket replacements at half the cost of the OEM hooks but I question quality. Happy to pay the OEM price it if it's truly one of those "better to stick with OEM" pieces of steel. Thought I would check in with the group. Thanks!
Search YouTube. Several videos there. From what I saw, it's a pain to get a couple bolts out
I have, the OEM are actually a good quality product. I have put both the chrome, and a set of red ones on my 16, and 18 trucks. They have held up quite well, and they come with the factory hardware to install, which you will need as the easiest way to remove the ones on the truck is to cut the bolt holding the driver side hook. You see exactly why you need to do this when you start, or the alternative is to loosen bumper, and other parts to make the space you need to extract the bolt.
Genius design!
Genius design!
Oh yea, I have been under there to take a peek. I see that one bracket/bolt on the drivers side that would get in the way of one of the two bolts in coming out. Im fully prepared to just cut the dang bolt off and then install the new one with the bolt head on the opposite side. Not sure why they didnt do this initially anyway!
I was thinking of doing red myself. I think it'll look good with the dark slate color truck, the red GMC badge, red All-Terrain badge and red recovery hooks.
Removal and install went fine. I didnt jack up the truck at all, so there was a little bit of me playing contortionist to cut that dang bolt, get the remaining out and put the new bolts and hooks in. In the end I learned one thing. There is a lot of black grease under there. Im still finding it in body parts I didnt even have under the truck! 😉
That being said, I like the red!
Next task is to recoat my nerf bars because the powder coat is starting to chip away.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
