Right blinker flashes , no brake light  , reverse camera stays on even while going forward?
I had the camera issue happen once when I went through a car wash and I was whiping off the dash while I was sitting still. I thought that something was wrong right away.It turned off after I restarted the truck in my garage. Then I looked in the owners manual. Turns out that you can turn it on and off manually by going into the settings. Try that.
 As far as the blinker goes, you probably have a light out on the right side. Turn your blinker on and walk around the truck.
I changed all 3 right side tail lite bulbs ,and that didn't fix it ,so then I put left side bulbs in right side same problem.  Right side bulbs work but just really dim . Even with the hazard on same thing only the ride side
