Ok, I got mine to work, thank you! BUT…… when I start the truck I have to go through 3 steps before I can get to CarPlay, when I start the sceen will come on with “pixel” on the connected devices, I have to hit that and then it will go to the android looking screen, then there is an icon called “autokit” and one I hit that I will get full screen CarPlay in which looks awesome. Is there something I’m missing to get it to default to the CarPlay screen like it did before when I start the truck?
Just now, Jeremy984 said:
Is your Carlin Kit flashing with the blue or green light?
Blue
Pic won’t load, I’ll try again later.
Edited by eppieguy
11 hours ago, eppieguy said:
Blue
I see the Pixel phone under Android Auto app but when I click on it, it says there is a time and date sync error, I click to fix it, and it then says can’t connect. I’m stuck in a loop.
On 8/16/2024 at 4:49 PM, EJS2015 said:
As many of you know, the refresh trucks have big screens for the infotainment system. For some reason, GM has not allowed Carplay to be fullscreen but Android Auto does have fullscreen. The way I got around this is by using a Tbox Plus from Carlinkit. These boxes allow you to not only do stuff like Netflix, Hulu, etc... on your screen, but also have wireless Carplay. These devices come preset to use Apple Carplay as the connection method to the car. This means the screen still won't fit fully. To fix this, you have to change the connection method by putting the attached file onto an sd card (format exFat), put into the Tbox Plus, and a message will pop up asking to change the connection method. Click Yes and it will restart and ask to connect an android auto device. And you are done! It sucks that you have to buy a device to get carplay full screen on these trucks. Fingers crossed GM decides to send an update to make this native.IMG_4077.thumb.jpg.f43e402b07fca4b66a440febb68214be.jpg
reverse.ini 236 B · 42 downloads
Do you have any problems using Siri with this setup? Thanks
No, the only difference is that you have a full screen, other than that everything looks / works the same but with some additional functionality in apps in which I haven't even started playing with yet. I'm still trying to figure out if there is a way to get it to automatically load like the OEM CarPlay app, so far I only have to now push the "Pixel" app on the screen and everything works, I would love to not have to be bothered with that.
have you tried to make a phone call? Did either you or the person you called have a really bad echo and delay?
I have not used the phone yet.
On 9/16/2024 at 5:26 PM, Jeremy984 said:
I have tried following this step by step with no luck. It won’t switch over to Android Auto after I put in the microSD card. HELP!
Sorry, I have not gotten on for a few days. Let's go through it. Are you using a Mac or a PC? On a Mac, open Disk Utility, click on the SD card, Erase, format to exFat, and scheme to Master Boot Record. Download that file and place it in the Tbox. On PC, right-click on the SD card, click format, select exFat for the file system, then click start. Download and put the file in there and put it into the Tbox. If that doesn't work, try to format it as fat32 instead of exfat.
I have to click on Pixel too for it to show the device. After that, it should auto-load Autokit though. If anyone here knows of a solution to get it to auto open the Android Auto for the Pixel, then please chime in.
I have never seen that before. Just to clarify, what happens if you click the Date / Time button and adjust it? If it is, maybe the Tbox has the wrong time. Do you have another vehicle that has Apple Carplay? If so, try plugging it into that one and if it loads, try setting the date and time and see if it's correct.
I have and I am not sure if it's just an issue with my phone, my brother's phone, or this, but I was on a call with him today and he said there was a 2-second delay.
I have checked the date and time settings in the Carlin Kit settings and my truck. They are both set to automatic. So it should sync. I tried to adjust each one manually to see if one feeds another. I can’t get this message to go away.
Also, the file to put on the SD card, mine starts with what looks like Chinese writing in step 1 and 2. Then repeats in English step 1 and 2. Is that right?
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,371 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
